52
[APP] Custom Slider - Root & Xposed required
  1. FloShr
    Cupcake Nov 12, 2016
    FloShr , Nov 12, 2016 :
    I can not open the app after the update. It start and close instantly after.
  2. tbone03
    tbone03 , Nov 12, 2016 :
    Just clear the app's data in phone settings. I did, and now it works!
  3. FloShr
    I will try again, I completely uninstall it and install again, it makes my phone freezing, have to force a reboot, a big mess.
  4. FloShr
    I did one more time uninstall and install again it's working, I don't know what was happening before. Thank you :)
  5. Weathon
    Honeycomb Nov 12, 2016
    Weathon , Nov 12, 2016 :
    Hey guys, sorry! working on a quick fix / solution right now.
    I need to delete your slider-specific data again, sorry!!!
    EDIT:
    Already pushed quick fix to Playstore/Xposed REPO :)
  6. steinba1
  7. Weathon
  8. FloShr
    Thank you, it was not a critic your app is awesome! ;)
    If nougat will be out on the oneplus 3 before xposed on nougat I will miss it!
    Weathon likes this.
  9. Weathon
    Honeycomb Nov 13, 2016
    Weathon , Nov 13, 2016 :
    Hey guys!
    I'm so ******* sorry for the screen freezes, if i were you i would start raging...
    You are the best community :)
    I just pushed an update to Playstore/XposedRepo.
    Please give me feedback if it works again.
    F_Florian_Shr_yYVo likes this.
  10. FloShr
    Cupcake Nov 13, 2016
    FloShr , Nov 13, 2016 :
    For the moment, everything works fine with the last update, I don't have any freeze :)
  11. ankitgarg10001
    Eclair Nov 13, 2016
  12. FloShr
    Just one think I wanted to set the media volume on 0 when I use silent mode, like we can do on vibration mode, but when I try to add an action music volume 0, it does not work. I don't know if you understand what I mean.
  13. ankitgarg10001
    Eclair Nov 13, 2016
  14. FloShr
    Sorry, it was for Weathon, the dev, I thought that it was him who said thanks about my previous comment ;)
    ankitgarg10001 likes this.
  15. Weathon
    Thats great to hear :)
    hm weird, do you have any other problems? Can you send me your settings please?
  16. FloShr
    It's the settings "audio volume", doesn't seem to work. I mean, it's working for the setting alarm, for the ringtone volume it's working but come back directly after to its position. And for music volume Nothing is happening.
    What I would like is a top position, all notifications, level of notification 5 for example, 5 as well for media, a middle position with vibration and level of media 0 (it's actualy possible because you implemented the setting you just have to enable Silence Media Volume. And a last position with everything mute except Alarm, so set the media volume to 0 as well in that position.
  17. Weathon
    Honeycomb Nov 14, 2016
    Weathon , Nov 14, 2016 :
    I see. I think i already figured out what the problem is, just need to fix it. (basically the audio vol is executed before setting it to all notifications. and if its still in silent e.g. when you execute the audio vol, it will jump back).
  18. maartenbiesbrouck
    Cupcake Nov 20, 2016
  19. maartenbiesbrouck
    maartenbiesbrouck , Nov 20, 2016 :
    Thanks for the support but i mean insteat of see all the notitification, it need to hide sensitive notifications :(
  20. Deactivated User
    Nov 28, 2016
    woolfie+ likes this.
