App drawer search engine via OnePlus 7 Pro
  1. Gunas_kurapati , via OnePlus 7 Pro , May 11, 2021 :
    As you can see these both images clearly
    When we upgraded to android 11 it's cool really but as you can see the different buttons available for a quick search.
    These buttons are not available in android 11 and its really annoying .
    I just wanna give a example I play games a lot and listen to music before android 11 it would hardly take me 3 touches to open the app that I desire but now in android 11 it's giving me a search that's cool but the issue is I'm also getting unwanted search engines.
    What my idea is place these buttons back where they belong and and also give search engine see if people like me just want app they tap music and tap Spotify or something when we need to search for a document in the device I think the search engine is useful.
    I want my app drawer quick access buttons.
  2. drl431
    Community Hero 2020 May 11, 2021
    drl431 , May 11, 2021 :
    Hi, you can submit a suggestion directly to OnePlus via the feedback forum. If using the community app, tap the red + button and select feedback.
  3. Gunas_kurapati , via OnePlus 7 Pro , May 11, 2021 :
    Did that still I think people also should see and suggest
    drl431 likes this.
  4. ryhold
    Honeycomb May 11, 2021
  5. Gunas_kurapati , via OnePlus 7 Pro , May 11, 2021 :
    Bro I want them and how you have them send me a screenshot
  6. Aaron2017
    KitKat May 11, 2021
    Aaron2017 , May 11, 2021 :
    Forgive me if i'm wrong, but could you both be searching for this setting in home screen settings?
  7. J4t1np4r3kh
    OnePlus Accessory Tester May 11, 2021
    J4t1np4r3kh , May 11, 2021 :
    I actually have it too.
    Strange that you don't. Probably some toggle somewhere 🤷‍♂️
  8. #8
  9. spot01
    Jelly Bean May 11, 2021
    spot01 , May 11, 2021 :
    I also have those available in android 11
  10. #10
  11. Aaron2017
    KitKat May 11, 2021
    Long press on an empty space on the home screen>select home settings>quick search gestures
    Shailender Sharma likes this.
  12. Gunas_kurapati , via OnePlus 7 Pro , May 11, 2021 :
    Ok bro I got it when I turn off scout settings what If I want both
  13. Aaron2017
    KitKat May 11, 2021
    I don't think that's possible, as far as i can tell it's off all together or choose between one or the other.
  14. #14
  15. ryhold
    ryhold , via OnePlus 7 Pro , May 11, 2021 :
    What is 'scout setting'? How do I get rid of those stupid buttons? Thank you. 😃
  16. Aaron2017
    KitKat May 11, 2021
    If you follow these steps you can turn it off completely
  17. ryhold
    I don't want to remove the search for apps completely. This is how start most of my apps.
    I just want extra space by removing those category buttons I never use.
    Cheers!
  18. Aaron2017
    KitKat May 11, 2021
    Ow right. Well, i don't think that's possible either, it's all or nothing as far as i know
