Apps from Play Store aren't "Auto-Updating"
  1. G_Rajun_Doal_Ieis
    Honeycomb May 31, 2017
    G_Rajun_Doal_Ieis , May 31, 2017 :
    I'm sure this is a broken feature as I have 2 apps that need updating which should happen automatically hence the featured name but it's not happening, any suggestions?
  2. Buzz417
    Gingerbread May 31, 2017
    G_Rajun_Doal_Ieis likes this.
  3. Wahoux
    Lollipop May 31, 2017
  4. G_Rajun_Doal_Ieis
  5. EN_RG
    EN_RG , May 31, 2017 :
    1)Check if you have disabled auto update in the settings
    2)maybe the permissions for the apps have changed so it's probably gonna need you to agree to them before updating
  6. G_Rajun_Doal_Ieis
    I have done both, I will wait and not update manually and see if the play store really does update apps, does it automatically update apps for you?
  7. Burgess85
    TheP4infvlWolf likes this.
  8. GDurgadas
  9. fevieira
    Froyo May 31, 2017
    fevieira , May 31, 2017 :
    usually, apps auto update only on WiFi and during charge. So, if you don't charge using wifi at the same time, apps will not update automatically.
    kuubeu likes this.
  10. kuubeu
    Froyo May 31, 2017
  11. F_Diganta_Koner_WIXu
    Jelly Bean Jun 1, 2017
    F_Diganta_Koner_WIXu , Jun 1, 2017 :
    If you have auto update turned on and it still does not update then clear cache of Google play services and clear the data as well and try. Let me know if this helps.
  12. jim262
    Ice Cream Sandwich Jun 1, 2017
  13. G_Ng_KWAN_YEIN_WUZo
    Eclair Jun 1, 2017
  14. Tiwi1990
  15. Deactivated User
    Jun 1, 2017
