21
Apps keep crashing on OP7T
  1. Y1579015016527
    Cupcake May 1, 2021
  2. KaustubhNaik95
    Froyo May 1, 2021
  3. Saahildhiman
    Eclair May 2, 2021
  4. C1574061141421
    Cupcake May 2, 2021
  5. itsmerahulgautam
    Eclair May 2, 2021
    itsmerahulgautam , via OnePlus 7T , May 2, 2021 :
    Stay calm and do update every application I have same problem before I updated all applications or do restart 1 or 2 time
  6. C1574061141421
    Cupcake May 2, 2021
    C1574061141421 , via OnePlus 7T , May 2, 2021 :
    My apps update automatically. And Done with rest as well. Nothing seems to be solved.
  7. itsmerahulgautam
    Eclair May 2, 2021
    How long have you been updated your smartphone
  8. P1597170459954
    Cupcake May 3, 2021
  9. KaustubhNaik95
    Froyo May 3, 2021
  10. KaustubhNaik95
    Froyo May 3, 2021
  11. G_madhur_bharani_
    Cupcake May 3, 2021
    G_madhur_bharani_ , via OnePlus 7T , May 3, 2021 :
    Try to clear android cache data and update all the application from the Playstore... Reboot your phone. It might helps. But if you are facing this issue for any single particular 3rd party application then the problem can be built version of that application (that application is not built for android 11 yet)
    Saurabh Kumar Banjare likes this.
  12. Sharun james
    Cupcake May 3, 2021
  13. G1577113764230
    Cupcake May 3, 2021
  14. KaustubhNaik95
    Froyo May 4, 2021
  15. Tokolozi
    Most Original Avatar May 4, 2021
    Tokolozi , May 4, 2021 :
    in wifi preferences turn off "intelligently select the best WiFi"
