12
Apps keep crashing on OP8
  1. SIDD7411
    Honeycomb Mar 23, 2021
    SIDD7411 , via OnePlus 8 Pro , Mar 23, 2021 :
    I did my job, by posting it.
    #41
  2. the_o2
    OnePlus 9 Series Expert Community Expert Mar 23, 2021
    #42
  3. Does!Compute
    KitKat Mar 23, 2021
    Does!Compute , Mar 23, 2021 :
    This is a Google issue, due to a botched up Android System Webview update.
    There is a fix rolling out by Google. Update Android System Webview to the latest version, i.e. 89.0.4389
    Then reboot your device
    #43
  4. Nasid
    Donut Mar 23, 2021
    #44
  5. Does!Compute
    KitKat Mar 23, 2021
    Check the web before placing the blame on OnePlus. This is a Google mess-up, due to a botched up Android System Webview update.
    #45
    Oxymarvin likes this.
  6. Nasid
    Donut Mar 23, 2021
    Nasid , via OnePlus 8 , Mar 23, 2021 :
    Thanks for your suggestions.
    #46
  7. shaurya.12sethi
    Cupcake Mar 23, 2021
    shaurya.12sethi , via OnePlus 8 , Mar 23, 2021 :
    Hello i am a user of oneplus 8 and i am facing an issue in which all the apps of the phone are closing again n again and it says"the app keeps closing"
    Please help me out with this... And even the same is happening with google search
    #47
  8. Does!Compute
    KitKat Mar 23, 2021
    If this helped, do mark it as the Best Answer for the thread, as it will help users facing the same issue find the solution quicker.
    Also, do search before creating a thread. This solution was already available on the forums. It will help you find the solution quicker.
    Cheers :)
    #48
    Lighthammer1 likes this.
  9. G_Ambu_SR_QDcD
    Eclair Mar 23, 2021
    G_Ambu_SR_QDcD , Mar 23, 2021 :
    Its actually issue from google side. Not only oneplus, other brands are also affected. Google is working on a fix, until then un installing web view is the only known fix
    #49
  10. Lighthammer1 , via OnePlus 8 Pro Glacial Green , Mar 23, 2021 :
    Selbes Problem oneplus 8 pro.....
    GMX Mail und Gmail Crash ....
    Playstore Updates nicht verfügbar
    Nach manuellem update des
    Android System Webview ist die Funktion wieder da und die Apps laufen.....
    Was für ein Drama so langsam keine Lust mehr auf oneplus....völlig unausgereift das oneplus 8 pro
    #50
  11. Altamshkh
    #51
  12. the_o2
    #52
    G_plusone likes this.
  13. jancro5
    Eclair Mar 23, 2021
    jancro5 , via OnePlus 8 , Mar 23, 2021 :
    Hello, I bought Oneplus 8 two months ago, switching from Apple and so far I had an awsome and unique experience, completely satisfied with my transition.
    But today I experienced something quite unusual for this kind of device (great specs and new). I cannot opet one game and that is Clash of Clans. I can open other games but not that one. When I try to launch it, it crashes and I get a notification from Games saying "Games is running. Tap for more information or to stop the app."
    I reinstalled the app and it worked but half an hour later it was crashing again?
    What should I do? I cannot reinstall the app every time its not working. Quite a shame for such an outstanding device.
    #53
  14. BeingIncog
    Nougat Mar 23, 2021
    BeingIncog , Mar 23, 2021 :
    https://forums.oneplus.com/threads/...lution-update-android-system-webview.1405651/
    #54
    Tokolozi likes this.
  15. B_Wrath
    Nougat Mar 23, 2021
  16. BeingIncog
    Nougat Mar 23, 2021
    #56
  17. B_Wrath
    Nougat Mar 23, 2021
    B_Wrath , Mar 23, 2021 :
    He can open other games. Just not clash of clans.
    #57
  18. Tokolozi
    Most Original Avatar Mar 23, 2021
    Tokolozi , Mar 23, 2021 :
    Maybe, They don't use webview? And CoC does?
    #58
  19. B_Wrath
    Nougat Mar 23, 2021
    Maybe. But I'm not so sure though.
    #59
  20. McJader
    Marshmallow Mar 23, 2021
    #60
    jancro5, B_Wrath and Tokolozi like this.
