Apps not updating on Oneplus 6 via OnePlus 6
  1. rajmanek36
    Cupcake Jun 21, 2020
    rajmanek36 , via OnePlus 6 , Jun 21, 2020 :
    I am not able to update or download apps on my Oneplus 6 and if I am not wrong it is after 10.3.4 update...
    I tried following but still of no use -
    1) cleared cache and app data of play store and disabled/enabled playstore app
    2) tried downloading on mobile data and with different wifis
    3) removed all google accounts and adding them again
    Is there any way to solve it except factory reset which I don't want to do. Thanks in Advance.
  2. Tarun_334
    Gingerbread Jun 21, 2020
    Tarun_334 , Jun 21, 2020 :
    Have you tried rebooting?
    If that doesn't work then try this:
    Go to Settings > Apps & Notifications > See all apps > Press the three dots on the upper right corner of the screen > Reset app preferences > Reset apps.
    rajmanek36 and Caoimhín like this.
  3. SeanPlus
    Ice Cream Sandwich Jun 21, 2020
    SeanPlus , Jun 21, 2020 :
    I had the exact same issue with my OnePlus 2 after an OxygenOS update. If I remember rightly, I had to back up everything then factory reset.
    rajmanek36 likes this.
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 21, 2020
    Caomhin , via OnePlus 6T , Jun 21, 2020 :
    Try the following,
    Clear the App info Cache and App info Storage for all 4 items
    Google Playstore
    Google Play services
    Google Services Framework (Search in Setting for this)
    Google App
    Restart the phone.
    It may take a while for Google to rebuild its services Playstore etc.
    Go through at least one full charge cycle from less than 50% Battery to give it time to do that.
    See if this rectifies the Playstore issue.
    rajmanek36 and Tarun_334 like this.
  5. rajmanek36
    Cupcake Jul 21, 2020
    Caoimhín likes this.
  6. lohith_dilip_kumar
    Cupcake Jul 31, 2020
  7. lohith_dilip_kumar
