aptX™ HD on OnePlus 5T
  1. assafaviv
    Cupcake Sep 18, 2018
    assafaviv , Sep 18, 2018 :
    Hi,
    I have a Bluetooth 5.0 recever that supports aptX[e]2122[/e] HD (48khz and 24Bit), I'm using my OnePlus 5T to stream music to my stereo system and unfortunately my op5t supports only 16bit and 44.1khz while on other devices which is not OnePlus supports 48khz (I'm not sure how many bits 16 or 24).
    is there any idea?
    thank you!
  2. kushalpandya
    Honeycomb Sep 18, 2018
    kushalpandya , Sep 18, 2018 :
    Usually phone will identify connected Bluetooth device's capability and use appropriate codec, but if that isn't happening in your case, you can go to Settings > Developer Options and manually change Bluetooth Audio Codec to aptX HD
    nombre74 likes this.
  3. Q1508649475849
    Gingerbread Sep 18, 2018
    Q1508649475849 , Sep 18, 2018 :
    a few questions.
    -do you have music files in 24bit?
    -does your sound system which connects to your receiver support 24bit (if it connects digitaly) and 48kHz?
    576 kbit (which should be the bitrate of aptx hd) may sound better with 16bit audio.
  4. assafaviv
    yes I have already done it, but without any change
  5. assafaviv
    all the answers to your questions is yes
  6. Q1508649475849
  7. assafaviv
    my phone connects to aptX[e]2122[/e] HD for sure
  8. Q1508649475849
  9. elanglois
    Lollipop Sep 18, 2018
    elanglois , Sep 18, 2018 :
    44.1 vs 48 will not sound any different. It will use whichever rate the original audio was recorded in. Otherwise, it would have to resample the audio which wastes CPU power and can cause distortions
    Your device is working fine. Why are you trying to force 48Khz? If the audio was ripped from a CD, then 44.1 is correct, not 48
  10. elanglois
    You can't get a better bit depth than the original recording
  11. victorzmartin
    Honeycomb Sep 19, 2018
    victorzmartin , Sep 19, 2018 :
    In developers menu, 3 below that Bluetooth codec option, you can force 16,24 or 32 bits... don't know if it helps
  12. Q1508649475849
    Gingerbread Sep 19, 2018
    Q1508649475849 , Sep 19, 2018 :
    thats right, but there are ways to listen to music with 24bits eg with tidal masters. (only via pc)
  13. elanglois
    Lollipop Sep 19, 2018
    elanglois , Sep 19, 2018 :
    Yes, but some people seem to think that trying to play 16 bit audio at 24 (or higher sampling rates) will magically make it sound better. The won't waste time or bandwidth trying to upscale the data.
  14. Q1508649475849
    the thing is there was never a problem with bit dephs or sample rate. 16bit and 44.1khz is just perfect. only bitrate eg with low quality mp3 can bottleneck quality.
    if one wants better sound he should go with new amplifiers and speakers.
    elanglois likes this.
  15. anupritaisno1
    KitKat Sep 19, 2018
  16. elanglois
    You do realize that Bluetooth is low bandwith and can't support data rates that high? Also, ALL bluetooth audio uses lossy compression.
    32bit is pretty much overkill since human sensitivity is around 20 bits. 384Khz?? 192 isn't enough?
    Do want high quality? Then why use lossy compression?? Get a freaking wire. Bluetooth isn't designed for that.
    However, check out AirAudio (WiFi).
  17. anupritaisno1
    KitKat Sep 19, 2018
    anupritaisno1 , Sep 19, 2018 :
    It's just that I'm too lazy to convert it
  18. anupritaisno1
    KitKat Sep 19, 2018
  19. elanglois
    convert what???
  20. assafaviv
    Cupcake Sep 19, 2018
    assafaviv , Sep 19, 2018 :
    aptX[e]2122[/e] HD was designed to play music up to 24bit and 48khz, which is indistinguishable from hi-resolution audio.
    I have a music (FLAC) with hi resolution audio and when I am playing it on my device the protocol makes downscaling...
    I think that the OS on the OnePlus 5T makes it happen.
    when im forcing the right bits and khz in the "developer options" nothing was changed.
