2
AR fix permanent for OnePlus phones via OnePlus 8 Pro
  1. smaberg
    Froyo Jul 14, 2020
    smaberg , via OnePlus 8 Pro , Jul 14, 2020 :
    Thanks to "Gav_W86" from OnePlus forums for fix
    Hi there, this seems to fix the AR not working in OnePlus 8 phones, simple steps, good luck.
    ______________________________________________
    Uninstall Google Services for AR
    REBOOT, this is important!
    Re-install Google Services for AR from play store
    try the AR apps again, worked on mine.
    Huigiebaby and Sorour80 like this.
  2. mbze430
    Froyo Jul 14, 2020
    mbze430 , Jul 14, 2020 :
    Goole Services for AR is a system app, you can't uninstall it without something like Titantium Backup. Can you verify the process. You CAN disable it.
    I am on OP8P
    or you mean to go to Google Play and uninstall the update?
  3. Starcommander
    Lollipop Jul 14, 2020
    Starcommander , Jul 14, 2020 :
    @Gav_W86 thanks
    Liehjan likes this.
  4. smaberg
    Froyo Jul 14, 2020
    I could, I'm on stock OnePlus 8 pro EU
  5. mbze430
    Froyo Jul 14, 2020
    I was able to make this work on the OP8P.
    Since the Google Play Service for AR is a system app on the OP8P, the process is a bit different.
    1) Go to Play Store and search for "Google Play Service for AR".
    2) You should have the option to uninstall it. Uninstall update
    3) Go to Settings -> Apps and look for the "Google Play Service for AR"
    4) Disable it & Clear Cache and Storage
    5) Reboot
    6) Go to Settings -> Apps and look for the "Google Play Service for AR"
    7) Enable Google Play Service for AR
    8) Go back to Play Store and upgrade "Google Play Service for AR"
    Testing working on Google Measure
    NOTE: It only works once and then it stopped working after you close out the app
  6. Sorour80
    Cupcake Jul 14, 2020
    Sorour80 , via OnePlus 8 Pro , Jul 14, 2020 :
    Thank You !!!
    That worked perfectly. I followed instructions in original post and worked brilliantly. I was able to uninstall completely (not uninstall updates only). Reboot . Reinstall. Reboot again and voila it worked. Closed chrome and tried again still work. Thanks for the tip.
    Update: unfortunately stopped working again 😟
  7. Huigiebaby
    Honeycomb Jul 14, 2020
  8. Gav_W86
    Starting Point Expert Community Expert Jul 15, 2020
    Gav_W86 , Jul 15, 2020 :
    just got an update from a OnePlus Bughunter:
    The issue reported by you is being taken care by our developer team and they are currently working on this. We will get back to you in case we would need more information. Meanwhile, we appreciate your patience and effort so far.
