2
Network/Connectivity AT&T Access Point Network Settings
  1. sonya_cee
    Eclair Jun 21, 2016
    sonya_cee , Jun 21, 2016 :
    Received my phone yesterday,yayyyyy.
    Went to to ATT to get a new nano SIM card and we couldn't figure out the APN/Data settings.... does anyone have some screen shots handy of what's worked for you? We searched and searched the internet and very minimal info is for the 3, and nothing has worked.
    Completely stumped!
    yairko and lenoelracso like this.
  2. F_Geoffrey_Brock_Lodder_
    Froyo Jun 21, 2016
  3. sonya_cee
    Eclair Jun 21, 2016
  4. sonya_cee
    Eclair Jun 21, 2016
  5. lenoelracso
    Honeycomb Jun 21, 2016
  6. sonya_cee
    Eclair Jun 21, 2016
    Two things:
    When I type that number and hit dial, the phone glitches and gives me a blank screen, but if you click in the right spot- you can get to where he is talking about.
    The real issue is I can't select the "LTE GSM auto PRL" setting he is talking about, when I do, it just goes back to the pre set network type of GSM auto PRL...
    oy vey...
  7. Lancelot_69
    Lollipop Jun 21, 2016
    Lancelot_69 , Jun 21, 2016 :
    This worked for someone with a similar problem. Try it, it might work, won't hurt.
    >First go to settings
    >Delete all apn Settings
    >Reboot
    >Then go back to Settings
    >Mobile Network Settings
    >Access Point Names
    >Open the three dots on the right hand corner
    > Reset toDefault.
  8. funmunke
    Marshmallow Jun 21, 2016
    funmunke , Jun 21, 2016 :
    I'm on ATT in NH and this is what's working for me:
    NAME
    ATT Nextgenphone
    APN
    nxtgenphone
    Proxy
    Not set
    Port
    Not set
    Username
    Not Set
    Password
    Not Set
    Server
    Not Set
    MMSC
    proxy.mobile.att.net
    MMS port
    80
    MCC
    310
    MNC
    410
    Authentication Type
    not set
    APN type
    default,mms,supl,hipri,fota
    APN protocol
    IPv4
    APN enable/disable
    (not on)
    Bearer
    Unspecified
    MVNO Type
    None
    pstuart likes this.
  9. sonya_cee
    Eclair Jun 21, 2016
    MMSC proxy?
  10. sonya_cee
    Eclair Jun 21, 2016
    Done, settings were a match of the post from NH's ATT... still nothing, i'm wondering if it's because I can't select the "set preferred netork type:" to LTE/GSM Auto PRL?
    Maybe I should do a reset and start from scratch?
    Does the fact there are two IMEI's have to do with anything, right now I am using IMEI1..
  11. Lancelot_69
    Shouldn't, are you using two sims? On your phone if you have, one Sim you should only have one bar indicated on your screen. Did you try switching to the other slot?
  12. funmunke
  13. sonya_cee
    Eclair Jun 21, 2016
    No just one, and yes we did. #fml
  14. sonya_cee
    Eclair Jun 21, 2016
  15. funmunke
    Dumb question - I only ask this because the One was legendary for this - is the sim card upside down?
  16. sonya_cee
    Eclair Jun 21, 2016
    I'm able to do text messages... so no it's not?
    funmunke likes this.
  17. Lancelot_69
  18. ghotch
    Gingerbread Jun 21, 2016
  19. matsam9
    Cupcake Jun 21, 2016
    matsam9 , Jun 21, 2016 :
    same problem and my settings were the same as what you specified. I called AT&T yesterday and talked to tier 2 support, and they said that the phone is too new and he should get back to me in two weeks (also submitted a ticket with one plus but haven't heard anything back yet).. I know the unofficial way to get it to work would be to just use another device IMEI (before the rep switched the IMEI I have speedtest results which prove I had LTE).. but I need the IMEI to match the network for insurance purposes/for it to be on record..
    sonya_cee likes this.
  20. matsam9
    anyone who got it to work with these settings, did you register your new phone? or did you just take the nanosim from your old phone?
