2
Network/Connectivity AT&T Access Point Network Settings
  1. ghotch
    Gingerbread Jun 21, 2016
    ghotch , Jun 21, 2016 :
    My experience with unlocked phones is to NEVER go to the ATT Store...hopefully you have the same size SIM card from whatever device you had or have. Same thing happened to me with the OPO and OP2. LTE worked initially, went to ATT store for new SIM....boom back to 4G/HSPA+ you go.
  2. matsam9
    Cupcake Jun 21, 2016
  3. sonya_cee
    Eclair Jun 21, 2016
    sonya_cee , Jun 21, 2016 :
    Do you have capability of texting and calling? I still have that, just not data.
  4. matsam9
    matsam9 , Jun 21, 2016 :
    but... as the guy said.. it seems to just be too new and they said they hadn't heard anything from the manufacturer (sounds like manufacturers have to give networks a heads up so it 'officially' works) so hopefully that process happens in the next week or two
  5. matsam9
    yup, texting and calling works, and again I was able to take screenshots of 4G/LTE before they changed the IMEI, which confirms what the tier 2 support guy said that it's obviously compatible (by virtue of bands and that it works) but it's not officially recognized in their system
  6. sonya_cee
    Eclair Jun 21, 2016
    Why does the sim size chage have anything to do with it? This is a third party ATT store, I have no choice but to get a new sim? I am ging from OPO to 3...
  7. matsam9
    size change has nothing to do with it (I don't think..), it's the IMEI change which basically comes up in their system as a phone they don't recognize yet
    Lancelot_69 likes this.
  8. sonya_cee
    Eclair Jun 21, 2016
    well poo
    Not sure what you mean by changing IMEI.. I guess I never had that option because I immidaitely had to get a new SIM card before I did anything?
  9. matsam9
    if you want it to 'just work' either try using the old IMEI number (might lock the sim if the system recognizes you just came from there) or try the same thing with a new sim card (register the old IMEI number and pop it into the new phone)
  10. sonya_cee
    Eclair Jun 21, 2016
    ahhhhh, ok- wasn't sure what exactly IMEI was - now I am understanding.
  11. sonya_cee
    Eclair Jun 21, 2016
    well slap us on this wrist for getting the cool new toys before they can even work yet, :p
  12. ghotch
    IMEI is the phones serial number on the network and is tied to the SIM card.
    sonya_cee likes this.
  13. matsam9
  14. sonya_cee
    Eclair Jun 21, 2016
  15. ghotch
    You are correct, it shouldn't matter.
  16. sonya_cee
    Eclair Jun 21, 2016
    Well I appreciate all the feedback guys, deifnitely helped clear some things up! :) cheers!
  17. lenoelracso
    Honeycomb Jun 21, 2016
    lenoelracso , Jun 21, 2016 :
    I went from OP1 to OP3, same sim card, sim slot size is the same in both OP1 and OP3.
    I read in a thread that LTE worked using the sim slot 2.
  18. sonya_cee
    Eclair Jun 21, 2016
    My Sim card went down in size from OP1 to OP3 which has the nano now.
    #38
  19. sonya_cee
    Eclair Jun 21, 2016
    I didn't have a choice when my SIM didn't fit due to size
    #39
  20. matsam9
    to update - I just called AT&T and they were able to get it changed in <5 mins. Call, ask them to use your old IMEI and put a note down indicating your new IMEI. i'll keep you all updated if I hear anything more
    #40
