9
AT&T LTE....If you are passing on buying you need to read this!
  1. bmaz121
    Froyo Jan 12, 2015
    bmaz121 , Jan 12, 2015 :
    I'm wondering, Did you do that? What equipment does the store have that tech support doesn't have?
  2. bmaz121
    Froyo Jan 12, 2015
    I am in LA too. I can't get my MMS to work but everything else does. Could you post your APN setting here if your MMS works?
  3. forgetfartuun
    Jelly Bean Jan 12, 2015
  4. benluca
    KitKat Jan 12, 2015
    benluca , Jan 12, 2015 :
    WAIT on that ebay solution!
    What you learned about AT&T is true, and it's great that you got some excellent help & advice from them. But rather than to chuck your phone to ebay, chuck the CARRIER! You'll find VERY fast speeds on T-Mobile or any of their MVNOs.
    I'm getting BLAZING fast LTE speeds on Metro PCS, an MVNO of T-Mobile. I have friends who are enjoying similar (great) results on Ultra ME and Simple Mobile.
  5. hoangr6
    Froyo Jan 12, 2015
    hoangr6 , Jan 12, 2015 :
    Try going to settings> mobile networks > APN> and at&t lte maybe? It works for my rogers
  6. AndyPober
    Ice Cream Sandwich Jan 12, 2015
    AndyPober , Jan 12, 2015 :
    You know that you just responded to a post that was made last June? Like before OP got registered with AT&T as an LTE-capable phone?
    The only outstanding issue with AT&T at this point is that they're beginning to roll out areas of band 20 LTE and the OPO doesn't support band 20. I got my OPO in July and LTE worked from the time the SIM went in. Nothing to see here. Move along.
  7. cupidaj
    Froyo Jan 12, 2015
    cupidaj , Jan 12, 2015 :
    I have AT&T and I have not had any problems running LTE H+ but it only goes to H+ while I am on a call other then that it always show LTE I live in riverside country California.
  8. kingyellav
    Donut Jan 12, 2015
    kingyellav , Jan 12, 2015 :
    I have at&t also and my late works just make sure your late is turned on. But sometimes it says no internet connection anyone.else have this problem?
  9. philli3sphan
    Froyo Jan 12, 2015
    philli3sphan , Jan 12, 2015 :
    Mine works fine with ATT LTE since day one it has worked perfect i get a few mbps download when i have one bar of coverage
  10. khvace
    Gingerbread Jan 12, 2015
    khvace , Jan 12, 2015 :
    One of my friends had this issue when he put a AT & T sim from his Iphone to the OPO. He was not getting LTE. After talking with AT & T and ensuring all the settings are correct, still it did not work. Later on the issue was found. His AT & T account still had the equipment as his old Iphone. Once he changed it to OPO, he was able to get 4G LTE.
    I also use AT&T with a new connection and I am able to get LTE
    kingyellav likes this.
  11. joan56
    Gingerbread Jan 13, 2015
    joan56 , Jan 13, 2015 :
  12. Mitchell
    Froyo Jan 13, 2015
    Mitchell , Jan 13, 2015 :
    Hmm I didn't run into this problem when I was with AT&T, but I also had to manually put in the APN just to get LTE in the first place. Maybe try deleting the APN and adding a new one?
  13. ashuroneplus
    Cupcake Jan 13, 2015
  14. OlfakD
    Jelly Bean Jan 13, 2015
    OlfakD , Jan 13, 2015 :
    I use cricket wireless and the speed is fine with me. Although it's not the best, Im getting a speed of 15mbps up and 10mbps down speed
  15. SugaDew
  16. SugaDew
  17. SugaDew
    SugaDew , Jan 13, 2015 :
    hey... another Floridian
  18. kingyellav
    Donut Jan 13, 2015
  19. SugaDew
    Go sit down somewhere....!!!!!
    LOL... you have the whole forum in an uproar... ....
  20. bmaz121
    Froyo Jan 13, 2015
    bmaz121 , Jan 13, 2015 :
    Nope. In the APN list should be one called "phone" Dumb name. Anyway if it is not there you have to add it and make it the Active APN. Call CS to have them give it to you or look up on the internet and I think it is posted in this forum several places.
