AT&T LTE
  1. Kumbaya
    Ice Cream Sandwich Jul 28, 2014
    Kumbaya , Jul 28, 2014 :
    I'm on cricket (part of AT&T as an MVNO). It says 4G but it is the same speeds for me as LTE.
    Keep in mind, the nomenclature is confusing because of the way the terms 4G and LTE are used in marketing literature.
    In real world usage I am getting great uploads and downloads with no issues.
    There is in the settings section of CM11 an option to add a control switch for LTE. When you activate this you will note that you go from 4G to H or HSPA (spelling).
    It works.
  2. jhodder
    jhodder , Jul 28, 2014 :
    Run Speedtest. Remember, the speeds will go up and down based on various network factors. I got 28Mbps in SF on 4G on my One, and only get 3Mbps in NYC on the same phone, no change.
    LouCap likes this.
  3. jechkt
    Froyo Jul 29, 2014
    jechkt , Jul 29, 2014 :
    I am from Canada, I recently received my phone. I am with Rogers, I cannot get LTE either(only h+)
  4. dmo
    Ice Cream Sandwich Jul 29, 2014
    dmo , Jul 29, 2014 :
    H+ = Fake 4G (HSPA+)
    H = HSDPA
  5. MrIanB
    Jelly Bean Jul 29, 2014
  6. jechkt
    Froyo Jul 29, 2014
  7. AndyPober
    AndyPober , Jul 29, 2014 :
    As of late last week OPO phones using their actual IMEI on AT&T are getting LTE service. The OPO notification bar dos not (normally) indicate LTE for LTE service but shows 4G. For HSPA service the indicator shows H. Looking at Settings -> About phone -> Status -> 'Mobile Network Type' should show LTE.
  8. wilbarger
    wilbarger , Jul 29, 2014 :
    To see what your real service is, go to settings>about phone>status and it will say LTE if you are on LTE. The 4G is a rom based issue. Some roms show 4G, some show LTE. There, aren't real facts nice instead of all the misinformation posted above.
    Radeon962 likes this.
  9. Radeon962
    KitKat Jul 29, 2014
    Radeon962 , Jul 29, 2014 :
    Exactly
  10. jechkt
    Froyo Jul 29, 2014
  11. wilbarger
    Well, from my own experience, the OPO has a weaker signal than most phones. Did you have LTE on your previous phone where you are? Do you have the correct APN settings for your provider?
  12. givemeyoursoul
    KitKat Jul 29, 2014
  13. jechkt
    Froyo Jul 29, 2014
  14. cnucherukuri
    Froyo Jul 29, 2014
    cnucherukuri , Jul 29, 2014 :
    good to know
  15. wilbarger
    You need to go to your provider store and have them check things out for you. I am not saying anything negative, but you need to read and learn a lot before getting into your phone settings. I do not want you to screw something up and I am not at all familiar with Canadian phone company settings. Your provider store should be happy to help you out.
  16. givemeyoursoul
    KitKat Jul 29, 2014
    givemeyoursoul , Jul 29, 2014 :
    Most people report fewer "bars" but that is meaningless. Lte in fewer places or slower speeds in the same places means something. Fewer bars is pointless
  17. wilbarger
    And, that is why I mentioned this. If he had LTE before, a weaker radio signal could be just enough to drop from LTE to slower connections.
  18. aspherical
    aspherical , Jul 29, 2014 :
    CM signal bars are a truer representation of actual signal strength. That's not the case with carrier phones.
    #38
    givemeyoursoul likes this.
  19. wilbarger
    Speedtest is not a representation of LTE. The connection status in settings is the only true way to know what connection you have on an android device. I can have a huge variation of speed results depending on signal strength/distance from tower.
    #39
  20. SincereSoprano
    Eclair Jul 29, 2014
    #40
