AT&T Reception Issues
  1. Tw8715
    Cupcake Oct 23, 2014
    Tw8715 , Oct 23, 2014 :
    Hi all~ Iv had my one plus for about 6 months or so. Lucky me! But one thing I hate about it is the reception. Even when I do get LTE... the bars drop from 1 bar to 4 bars.. Going back and forth and not constant.
    Web surfing and apps are painfully slow with poor connection! WHAT TO DO?!
    BUT! On my girlfriends AT&T iPhone 6.. it always has better connection then my one plus :(
    Same network.. Same places together.. Even when running speed test.. Her iPhone is much faster.
    Im about to throw in the towel and go pick up a Samsung Note 4 tomorrow :(
  2. Tw8715
    OH I forgot to add. My APN is set to ATT PHONE and is set to LTE/GSM auto (PRL) are those the correct settings?
  3. lostLambda
    Lollipop Oct 23, 2014
  4. rajkumar
    Jelly Bean Oct 23, 2014
    rajkumar , Oct 23, 2014 :
    Hmmmm. Note 4 is a great device. I'd you can afford it then you must pick it. Used for couple minutes on the demo unit meant for display. It's wonderful I must say the finish the performance the camera all were cool. The new touchwiz was also easy on the eyes and good.....
    I'm planning to buy myself one for the Christmas
  5. Tw8715
    Like i said my girlfriends phones on the same at&t towers has great receptions and speed. So changing to verizon towers dosnt seem like a smart move.
  6. merrickmb
    Froyo Oct 23, 2014
  7. mario24601
    Froyo Oct 23, 2014
  8. jadecolour
    Ice Cream Sandwich Oct 23, 2014
    jadecolour , Oct 23, 2014 :
    Search and submit a JIRA issue on CyanogenMod website. They both use Qualcomm baseband chips, and should not be an HW issue unless OPO's antenna design is crap.
  9. jadecolour
    I am on AT&T, too. The phone should automatically select the proper APN to connect to, I believe.
  10. bestlands
    KitKat Oct 23, 2014
    bestlands , Oct 23, 2014 :
    OK so every Ody here check my Sig down below it is proved to work cuase I have tried it and created the guide
