[Answered] At the OnePlus 3/3T's natural DPI of 401 the volume indicator notification doesn't scale properly.
Thread Status:
Not open for further replies.
  1. G_EVR
    Honeycomb Jan 4, 2017
    G_EVR , Jan 4, 2017 :
    Set "Smallest Width" to 430 in Settings>Developer's Options to achieve the OP3/3T's native 401DPI and everything scales properly except the volume level notification that doesn't span from one corner to the other of the screen.
  2. arnabJ
    arnabJ , Jan 4, 2017 :
    It's that by design. It's not an issue.
    App Notifications span from one corner to next, not Volume Level PopUp.
  3. runboy93
    Jelly Bean Jan 4, 2017
  4. G_EVR
    It's not by Google's design. I'm running stock Android 7.1.1 on my Nexus 5x and the volume notification bar scales appropriately. The OnePlus 3T scales the same way except at the screen's natural PPI of 401.
  5. G_EVR
    You are correct. It is a mistype, but the issue still applies.
  6. 4tr4s
    Honeycomb May 15, 2017
    4tr4s , May 15, 2017 :
    same issue. anyone having experience with this issue being fixed in the latest beta?
  7. Jeff Lee
    Eclair Jun 15, 2018
    Jeff Lee , Jun 15, 2018 :
    Hi @G_EVR,
    Good day! This is from OnePlus Bug Hunters.
    How are you doing? If the issue still persists on the same build, then we highly recommend that you install the latest software updates that were released. If the same issue is present on the latest build , we further suggest that you create a new thread with the updated details. For any other bug report, please create a different thread for each one.
    On that note, please be informed that we will now close this thread.
    Thank you and have a great day.
