Audio and video issues via OnePlus 7 Pro
  1. mohammed shaheen hussain , via OnePlus 7 Pro , Sep 18, 2020 :
    Hi Im Shaheen, I'm using a Oneplus 7 pro.
    Ive started facing problems with audio and video files since months now. Kept waiting for updates but it still couldn't fix it yet.
    Everytime this happens I have to restart my device to fix it. But it happens again after some time.
    Please help to fix this issue.
  2. Bobbie63
    Marshmallow Sep 18, 2020
    Bobbie63 , Sep 18, 2020 :
    What app do you use for playing these files?
  3. #3
    Bobbie63 likes this.
  4. Bobbie63
    So I guess it's not the app you use. I thought you might use some specific app the play music and videos but now you also say it doesn't play from galary either I start to wonder.
    I could say do a factory reset but that's a little too easy and quite some work to reinstall everything again but I haven’t got any other solution. Maybe it’s the best you submit a bug here with the detailed info and see what the bug hunters will say
  5. mohammed shaheen hussain , via OnePlus 7 Pro , Sep 18, 2020 :
    Okay thanks alot man.
