Audio player pausing automatically
  1. A1544616408496
    Cupcake Jan 28, 2020
    A1544616408496 , Jan 28, 2020 :
    Hi one plus team,
    For the past few days I'm facing this issue.
    When I'm playing music through app players if I lock a device then the music is pausing automatically it's not playing then I again I need to play the music after few seconds again the music is pausing.
    Could you please check and fix this issue .
    Thanks,
    Aravinda Kumar V
  2. Caomhin
    KitKat Jan 28, 2020
    Caomhin , via OnePlus 6T , Jan 28, 2020 :
    In Settings, Battery, Battery Optimisation. Check if the apps you use for music are set to Intelligent control, if they are set to Optimize then OOS will shut it down when phone is locked sometimes.
    If it still happens under Intelligent control then set to Do Not Optimize and see if that fixes it.
    However if Do Not Optimize is set for the app or apps they will use more battery running in the background.
