Audio tuner settings not working
  1. Adeel81a
    Gingerbread May 19, 2017
    Adeel81a , May 19, 2017 :
    On Sounds there's a settings so named audio tuner
    It seems to be working when i play songs on the earphone and enter the menu. With working i mean there's a slight sound difference when i change the position of bars but when i switch the menu that difference is gone the bars are on the same position but the sound difference is gone. Is it supposed to work only when im in the menu or what
  2. Rodriguezz
    Gingerbread May 21, 2017
    Rodriguezz , May 21, 2017 :
    That audio tuner thing is garbage. Everything sounds better with it off. Just ignore it.
  3. amitssj
    Honeycomb May 22, 2017
    amitssj , May 22, 2017 :
    Audio tuner feature is very confusing. No difference if you either enable it or disable, i disabled audio tuner completely I am using Black music player and it has its own equalizer and is working flawlessly.
