audio usb c
  1. Migueltbc
    Cupcake Jul 2, 2018
    Migueltbc , Jul 2, 2018 :
    Is it possible to get the audio from the phone through the USB C port and to manage the songs from the headphones?
    ¿Es posible obtener el audio del teléfono a través del puerto USB C y administrar las canciones desde los auriculares?
  2. JelleZon
    Lollipop Jul 2, 2018
    JelleZon , Jul 2, 2018 :
    I tried it on my 5t with usb C headphones from HTC. Did not work.
    Migueltbc likes this.
  3. glenn
    Ice Cream Sandwich Jul 3, 2018
    glenn , Jul 3, 2018 :
    did you try turning on ITG first?
  4. Migueltbc
    Cupcake Jul 3, 2018
    JelleZon likes this.
  5. m4rc3ll0k
    Eclair Jul 3, 2018
  6. glenn
    sorry I meant OTG. Typo. Have you tried that?
  7. Migueltbc
    Cupcake Jul 3, 2018
    Migueltbc , Jul 3, 2018 :
    Yes, I tested with OTG, I even bought a Grom Audio Wirelinq Smart Android Type C CAR cable converter for iPod USB Port and it did not work either
  8. glenn
    bummer!!!!
  9. Migueltbc
    Cupcake Jul 3, 2018
  10. glenn
    means sorry bro. Bad luck! someone else might have some other ideas
  11. Mauk1uss
    Gingerbread Jul 3, 2018
    Mauk1uss , Jul 3, 2018 :
    OTG on and set USB configuration to audio source? I did not try this , just wanting to help
  12. Migueltbc
    Cupcake Jul 3, 2018
    I've tried with all the possible configurations of USB, but the only way I've been able to get audio out of the car has been through the jack and via Bluetooth and I wanted to try it for usb c to see if it had better sound quality
  13. kmurithi
    Cupcake Jul 3, 2018
    kmurithi , Jul 3, 2018 :
    HTC USB headphones are not interchangeable with other brands. Proprietary just like Apple, look similar but doesn't work the same.
  14. PAPZI1957
  15. Migueltbc
    Cupcake Jul 3, 2018
  16. paultruland
    Gingerbread Nov 22, 2018
    paultruland , Nov 22, 2018 :
    Sorry late here, just returned to OnePlus with a 6T after being gone since my One. I too bought the Grom Wirelinq Type C, and did get it working by disabling USB streaming in the Dashlinq app. The caveat is that the only sound I can get are though the Dashlinq plug ins.
  17. Migueltbc
    Cupcake Nov 22, 2018
  18. Joel Mateo
    Gingerbread Dec 4, 2018
  19. ghostofcain
    Marshmallow Dec 4, 2018
    ghostofcain , Dec 4, 2018 :
    Open beta for OP3(T) is dead, but it is available in latest OOS, 5.0.7
  20. Joel Mateo
    Joel Mateo , Dec 4, 2018 :
    I'm saying for oneplus 6/6t
