12
Audio volume changes itself
  1. ManUnited123 Cupcake Nov 25, 2017
    ManUnited123, Nov 25, 2017 :
    Hi, after the newest update to Android 8.0 my op3 has begun to automatically decrease and also increase the volume of Spotify YouTube and musixmatch. If the screen locks or I leave the app the volume starts to change in roughly 5 second periods. The volume is then decreased for about 1 second until it increases again to my actual volume level.
    I never had any issues with the op3 but this is really annoying and makes it basically impossible to listen to music or watch YouTube. If the app stays open, then there are mostly no volume problems.
    Thank you for any advice you can give me
  2. G_Alex_Simpson_KPeB Cupcake Nov 27, 2017
    G_Alex_Simpson_KPeB, Nov 27, 2017 :
    Hi
    Ive had the exact same problem since the update, very annoying first problem with a phone thats been pretty perfect until now. I've looked through the settings and have found no fixes so far.
  3. Chrizari3 Donut Nov 27, 2017
    Chrizari3, Nov 27, 2017 :
    Hey,
    I am experiencing the same issues ever since the update to Android 8.0 and haven't been able to figure out a solution yet. The decrease in volume also happens when I type (searching in Spotify) as well as the moments that ManUnited123 mentioned already. Really hoping a fix a found soon.
  4. S1511793977437 Cupcake Nov 27, 2017
    S1511793977437, Nov 27, 2017 :
    Similar issue here when I'm listening to music through Deezer. Thought it could be my new headphones but they were absolutely fine for a few days end of last week. I then did the OTA update to 8.0 Saturday and have started experiencing the issue you describe. I've tried disabling and removing an Equaliser app I had installed and this made no difference.
    Edit: tried clearing the System Cache and Deezer App cache. It seems to have made the problem worse.
    JoeBall, crazydutchchica and rafajako like this.
  5. G_Warren_Veragoo_TLAK Cupcake Nov 27, 2017
    JoeBall and crazydutchchica like this.
  6. tweetingsander Gingerbread Nov 27, 2017
    tweetingsander, Nov 27, 2017 :
    There was already a bug for this, for me it seems to be solved when I do NOT have my phone on mute with the slider on the side. When it is in either of the other settings, the volume does not randomly change, only when I put it to "silent" might be a good workaround for the time being.
  7. G_Alex_Simpson_KPeB Cupcake Nov 28, 2017
    G_Alex_Simpson_KPeB, Nov 28, 2017 :
    Thanks sander, switching to do not disturb and then changing the settings so it works like silent mode fixed the problem.
    JoeBall and tweetingsander like this.
  8. Mervyn86 Cupcake Nov 29, 2017
    JoeBall likes this.
  9. Chrizari3 Donut Dec 10, 2017
    Chrizari3, Dec 10, 2017 :
    If in Silent mode, and you enable vibrations, the bug is gone as well.
    So either Do not disturb or Silent w/ vibrations to get around it.
    JoeBall and T1511772367364 like this.
  10. Ajaya14 Cupcake Jan 18, 2018
    Ajaya14, Jan 18, 2018 :
    I am facing the same problem. But in my case the overall volume of the instrument became very down including phone call, media and YouTube etc.....
    JoeBall and Spike83420 like this.
  11. Arokmin Cupcake Feb 1, 2018
    JoeBall and S1526982537710 like this.
  12. crazydutchchica Cupcake Mar 2, 2018
    crazydutchchica, Mar 2, 2018 :
    Doesn't seem to work for me!
    JoeBall likes this.
  13. pimblokland Eclair Mar 8, 2018
    pimblokland, Mar 8, 2018 :
    OnePlus 5T The volume of the media is changing every time, don't know when or why.
    This is very disturbing because I use a Bluetooth headset and every time the volume has changed I don't hear anything.
    Can anybody explain how to fix the settings ???
    In the other replies I did not find a good solution.
    JoeBall likes this.
  14. crazydutchchica Cupcake Mar 8, 2018
    crazydutchchica, Mar 8, 2018 :
    Hi,
    I read on Google that it had to do with your headphones and in my case it is true. When the headphones are not connected, I can listen to Spotify, watch Netflix and YouTube without an issue. As soon as I connected the headphones, the volume went crazy again. And when I tried it with my boyfriend's headphones...no issue at all.
    JoeBall likes this.
  15. Habced Cupcake Apr 15, 2018
    Habced, Apr 15, 2018 :
    Hi, Does anyone have a fix?
    I have Oneplus 5, android 8.0.
    It changes it's volume regardless if it's on silent or do not disturb or ring mode. It will bug out on any app. Speakers, bluetooth, or wired, doesn't matter as well. Will keep changing its volume. Clearing cache did not work.
    JoeBall likes this.
  16. G_Imaad_Azhar_rPEi Cupcake Jul 12, 2018
    G_Imaad_Azhar_rPEi, Jul 12, 2018 :
    Heyya,
    I suggest you reboot into recovery mode and clear cache one time. this worked pppfor me. so far so good.
    Hope this helps :)
    JoeBall likes this.
  17. Yuvi0181 Donut Sep 28, 2018
    Yuvi0181, Sep 28, 2018 :
    Bro Can U pls repeat these steps more specifically [e]1f64f[/e]
    JoeBall likes this.
  18. X1538420162188 Cupcake Oct 1, 2018
    X1538420162188, Oct 1, 2018 :
    I'm struggling with the same issue.
    Here it seems to be a software issue since it desapears if I turn off the system equalizer.
    I just bought the phone and the before I updated to the newest android version, I did not notice the problem.
    All the methods discribed here did not work for me unfortunately.
    Does anyone know any other method?
    Otherwise illI need to continue with my equalizer off till some updates...
    JoeBall likes this.
  19. O1536212152768 Cupcake Oct 24, 2018
    O1536212152768, Oct 24, 2018 :
    ManUnited123
    Thank you for any advice you can give me​
    Not sure if you found a resolution for this but was facing the same problem on my oneplus 6 with Apple airpods. The solution works now and am not facing this volume pitching up and down anymore.
    Go to Settings-Sound-Earphone Mode- Disable Bluetooth Absolute Volume.
    Now Unpair the bluetooth headsets and repair them.
    This should take care of the issue, let me know if it works.
    JoeBall likes this.
  20. mjstuart Cupcake Nov 11, 2018
    mjstuart, Nov 11, 2018 :
    This fixed my issue with volume, thank you!!
    OP: This is not an acceptable fix, please fix this the proper way. Having to adjust two sets of volume is annoying to the max.
    JoeBall likes this.
