Auto Brightness and Battery
  1. GaganKeerthi Cupcake Nov 9, 2018
    GaganKeerthi, Nov 9, 2018 :
    After the android 9 pie update I find the auto brightness option to be useless.
    Even in dark no light conditions I find the brightness to be around 30 to 40 %.
    Pls fix this.
    And also after 9.0.2 update the battery capacity is not soo gud.
    I feel the battery to be draining very fastly, anyway thanks to the dash charging[e]1f609[/e]. So pls try to fix this also...
    And let me know that only I'm facing this issues
  2. U1534432541051 Cupcake Nov 9, 2018
  3. G_Albin_Mathew_gVaw Cupcake Nov 9, 2018
  4. Kytharsis Lollipop Nov 9, 2018
    Kytharsis, Nov 9, 2018 :
    Read!
  5. G_Albin_Mathew_gVaw Cupcake Nov 9, 2018
  6. Kytharsis Lollipop Nov 9, 2018
    No such thing as "battery backup" since there's no backup happening. Post screenshots of your battery graph so we can figure out what's causing it.
  7. B_Wrath Lollipop Nov 9, 2018
    B_Wrath, Nov 9, 2018 :
    I have given up... You keep up the good work...
    Kytharsis likes this.
  8. G_Albin_Mathew_gVaw Cupcake Nov 9, 2018
  9. Kytharsis Lollipop Nov 9, 2018
    Deactivated User likes this.
  10. G_Albin_Mathew_gVaw Cupcake Nov 9, 2018
    G_Albin_Mathew_gVaw, Nov 9, 2018 :
    thank you bro,will do that[e]1f44d[/e]
  11. G_Albin_Mathew_gVaw Cupcake Nov 9, 2018
    before the update,my on-screen time was 5-6hrs
