Auto brightness issue
  1. aim1999x
    Cupcake Mar 25, 2015
    aim1999x , Mar 25, 2015 :
    Recently I started having issues with auto brightness. When it is enabled sometimes my phone will have super bright screen. The colors are all wrong like on monitor when you turn brightness and contrast too high, they bleed.
    All it takes is turn screen on and off and it is fine. This never happens when I don't use autobrightness. I am using stock rom latest version. Any ideas what could be causing this , should I be concerned ?
  2. EpicSwirly
    Mar 25, 2015
    EpicSwirly , Mar 25, 2015 :
    Try disabling color enhancement( I think that's what its called) under settings, display.
    Tobikage and LostPorcupine like this.
  3. aim1999x
  4. LostPorcupine
    KitKat Mar 25, 2015
  5. EpicSwirly
    Mar 25, 2015
    What about adaptive backlight? Turn that off.
    Tobikage likes this.
  6. aim1999x
    Ok I turned adaptive light off. Will see if it makes any difference. What is live display ? I didn't see that in the settings.
  7. Munksd
    Donut Mar 25, 2015
  8. uvankarthik
    Gingerbread Apr 1, 2015
  9. Buzz417
    Gingerbread May 31, 2015
    Buzz417 , May 31, 2015 :
    Try the following
    1.Turn iff Adaptive brightness, Ambient display, Adaptive backlight and color enhancement under display settings
    2.under Status bar settings, turn off brightness control
  10. yankster1+
    Donut Oct 7, 2015
