3
Auto Call Recorder Oxygen OS 4.5.0 , One Plus 3T
  1. nirajbhusal
    Gingerbread Oct 3, 2017
    nirajbhusal , Oct 3, 2017 :
    Hello !
    I can't see option to enable Auto Call Recording in my One Plus 3T with Oxygen OS version 4.5.0 . How to enable it ??
  2. jungleboyE
    Honeycomb Oct 3, 2017
    jungleboyE , Oct 3, 2017 :
    open dialer -- click on three vertical dots on right top side-- and there you will find the option to auto record
  3. F_Mamun_Chowdhury_ZLLF
  4. abhi1+3
    Froyo Oct 3, 2017
  5. wjztusa
    Froyo Oct 3, 2017
  6. eec98
    Cupcake Oct 3, 2017
  7. amarnathp2478
    Cupcake Oct 3, 2017
    amarnathp2478 , Oct 3, 2017 :
    Hi
    .. thanks for the info.. just wanted to know where the recordings are being stored.. if you can share the path in the local storage would be good..
    Thanks in advance..
  8. F_Irfan_Mughal_fCdV
    Donut Oct 3, 2017
  9. CosminOlteanu
    G_Mr_...., insmuh and eec98 like this.
  10. F_Wout_van_Gessel_DOSz
    Eclair Oct 3, 2017
    F_Wout_van_Gessel_DOSz , Oct 3, 2017 :
    you have to change the build.prop. change region from overseas to cn and reboot. than it shows up.
    it's only legal in China and India, not in other countries.
    method needs root access.
    G_Mr_.... likes this.
  11. G_Shamim_Azad_HlAn
    Cupcake Oct 3, 2017
    G_Shamim_Azad_HlAn , Oct 3, 2017 :
    For that reason... I haven't got the option... Under call options.....
  12. elanglois
    Lollipop Oct 3, 2017
    elanglois , Oct 3, 2017 :
    It's only there in India
    Sun90 likes this.
  13. F_Amit_Kumar_Bidaser_NXR
  14. humanzqzr
    G_Mr_.... and mehuljain1987 like this.
  15. amarnathp2478
    Cupcake Oct 3, 2017
    I am from india and I have the option in my Op3 but after recording completed not known where its being stored with the recordings.. just wanted to make sure its stored some where and can retreive the same when needed..
  16. G_Mr_....
    Jelly Bean Oct 3, 2017
    G_Mr_.... , Oct 3, 2017 :
    Thanks.
  17. Sun90
    Starting Point Expert Oct 3, 2017
    Sun90 , Oct 3, 2017 :
    Open file manager app.
    And under categories select Audio.
    You will find call recording files there.
    Long press on it to select and press 3dot menu overflow and chose details .
    You will find the path in the pop up screen.
  18. Kalpesh.kalgutkar
    Cupcake Oct 3, 2017
  19. F_Alauddin_Akash_LNID
    Ice Cream Sandwich Oct 3, 2017
    CosminOlteanu likes this.
  20. CosminOlteanu
    CosminOlteanu , Oct 3, 2017 :
    Thanks for info. But I'm ok with official os.. If I want recorder there are so many apps..
    F_Alauddin_Akash_LNID likes this.
