4
Auto Call Recording
  1. Artemus.
    Community Hero 2020 Feb 18, 2020
  2. sagittarioinverso
    Donut May 6, 2020
    sagittarioinverso , May 6, 2020 :
    I did this.
    1) Where the call record file is located?
    2) How can Tasker (I have it) avoid to redo adb after reboot?
  3. sagittarioinverso
    Donut May 11, 2020
  4. Artemus.
    Community Hero 2020 May 11, 2020
    Artemus. , May 11, 2020 :
    Are you in a country other than India where it's not officially supported?
    drl431 and Caomhin like this.
  5. sagittarioinverso
    Donut May 11, 2020
    sagittarioinverso , May 11, 2020 :
    Italy. But I read somewhere that it's possible to make it permanent.
  6. Artemus.
    Not officially, no. Why are you wanting to keep recorded calls anyway?
  7. sagittarioinverso
    Donut May 12, 2020
    sagittarioinverso , May 12, 2020 :
    For security reason.
  8. #28
    Artemus. and Caomhin like this.
  9. sagittarioinverso
    Donut May 12, 2020
  10. Caomhin
    Community Hero 2020 May 12, 2020
    Caomhin , via OnePlus 6T , May 12, 2020 :
    This can happen when changing some system settings, particularly for apps that will only run modified temporarily.
    Also your service provider may be blocking the recordings from happening as it's a legal issue in Europe.
    You would need to go back to where you read about it being able to set permanent. Maybe XDA might help.
    https://www.xda-developers.com/record-phone-calls/
    Artemus. likes this.
  11. sagittarioinverso
    Donut May 13, 2020
  12. Caomhin
    Community Hero 2020 May 13, 2020
    Caomhin , via OnePlus 6T , May 13, 2020 :
    Suggestions in the link posted above.
  13. sonnyhaze
    Gingerbread May 17, 2020
    sonnyhaze , via OnePlus 7 Pro , May 17, 2020 :
    That's why you use tasker like stated above.
  14. sagittarioinverso
    Donut May 18, 2020
    sagittarioinverso , May 18, 2020 :
    Can you explain in detail? I don't understand how to do this.
  15. sonnyhaze
    Gingerbread May 19, 2020
    sonnyhaze , May 19, 2020 :
    sagittarioinverso
    Follow these steps (No Root Required)
    I wrote this for beginners mainly. I factory reset my phone and went through the process so I could write it in great detail.
    1. Go to settings>about phone> then click on Build number box 7 times. You will see a dialog appear telling you that you are now a developer. From go to settings>system>developer options and turn on USB debugging.
    2.I'm guessing you are not sure how to use adb. So lets start there. The easiest way I can think of for you to download a tool called Tool All In One. Here's the link:
    https://forums.oneplus.com/threads/...ck-twrp-factory-image-stock-recovery.1176717/
    3. After installing tool you prob will need to install drivers so plug in your phone and open the tool and click install drivers.
    4. You will need two apps to turn call recording on. Search "joneplus tools [adb/root]" and "tasker". Both can be downloaded from the play store. Tasker which is like $3.49.
    5. Once downloaded open joneplus tools it will instruct to enter an adb command in order to use it that command is:
    adb shell pm grant net.jroot3d.joneplustools android.permission.WRITE_SECURE_SETTINGS
    6. To do this go back to Tool all in One and click "advanced options" click the bottom bar that says " open free terminal with adb and fastboot privileges." In the box that opens copy the command above and paste it and hit enter.
    Now if you can open joneplus tools.
    7. In joneplus tools click the bar that says "import profile for tasker users. That will open a browser to a certain page. Click the green button that says "import". A window from tasker will open asking you to accept terms so hit "ok". When tasker opens click the check mark at the top right. On the next page do the same. Next it will ask if you want to learn how to create your first automation profile click "no".
    8. Now you need to go back to the browser and click the "import" button again. It will then ask you if you are sure so click "yes". Do you want to enable click "yes". Run lauch task "restore call recorder" now? click "yes".
    9. Open phone app and click the three dots in top right. Click settings. You will now see call recording at the top. Turn it on and you are good to go!!!
    10. If you keep getting notifications from tasker choose the option to turn the off completely. You dont need or want them.
    11. Turn off battery optimization on both apps.
    NOTE:
    Technically you can turn on call recording by entering a single command but I DO NOT recommend it. If you want to try it just going to Tool all in one, clicking advanced options then opening the adb terminal and entering this command:
    adb shell settings put global op_voice_recording_supported_by_mcc 1
    Then open phone settings and turn on call recording.
    HOWEVER, whenever your phone restarts you will have to go back into the tool and enter the command again.
    Thats what's great about tasker. If you follow the 11steps above when your phone restarts call recording will always be on.
