14
Auto display brightness pathetic
  1. SubhashNayak
    Honeycomb Nov 20, 2019
    SubhashNayak , Nov 20, 2019 :
    Yea. Same problem on 7T Pro, its very slow and sometimes never changes, need to do it manually.
  2. MikeKempi
    Cupcake Nov 20, 2019
    MikeKempi , Nov 20, 2019 :
    Are you guys on 10.0.4?
    This update seems to have fixed this for me.
    It should be available when you go to updates in system settings.
    let me know!
    EDIT: thought it was fixed, but the problem still exists, but its not really a problem for me as it happens maybe once a day.
    it seems like manually setting the brightness when it occurs, will make the system learn and the problem will (almost) fix itself
    masi0 likes this.
  3. H1564593442610
    H1564593442610 , Nov 20, 2019 :
    My eyes are hurting a lot dur to its pathetic display brightness. i would recommend user not to buy 7 series phone of one plus
  4. TopHappyMe
    Froyo Nov 20, 2019
    TopHappyMe , Nov 20, 2019 :
    Bit strong! It's plenty bright, just the auto brightness often gets it wrong. I do think mine has gotten better but that's based on anecdotal evidence.
  5. redford
    Eclair Nov 20, 2019
  6. G_Isaac_Margolis_Jycu
    G_Isaac_Margolis_Jycu , Nov 20, 2019 :
    ditto here. its constantly adjusting to the wrong brightness for the environment. specifically whenever you play a video it suddenly goes darker and even if you adjust it manually it adjusts it again after a few seconds. also when taking out of the pocket, it takes far too long to become bright.
  7. G_Ratna_Kiran_NtpY
    Cupcake Nov 21, 2019
    G_Ratna_Kiran_NtpY , Nov 21, 2019 :
    I think it is working fine for me after making manual adjustments multiple times in different locations,it is taking too much time to adapt.
  8. depta
    Cupcake Nov 22, 2019
    depta , Nov 22, 2019 :
    Same issue here. auto adjusting doesn't seem to work much and also few times a day it becomes really dimmed without reason... thinking about returning the phone
  9. redford
    Eclair Nov 23, 2019
    redford , Nov 23, 2019 :
    it's to late for returning phone for me. but after one month with OnePlus 7t pro, I have to say that I probably will not buy phone of this company anymore. it should be bugless, super fluid experience, and to be honest, it's not :(
  10. sup3rbuck
    Cupcake Nov 23, 2019
  11. gjseth
    Cupcake Nov 24, 2019
    gjseth , Nov 24, 2019 :
    Yeh on 10.0.4 problem is still there. Getting fed up with it. have turn off the auto brightness. This should be addressed asap. Its irritating as hell to manually keep changing the brightness.
  12. RaBjo
    Froyo Nov 24, 2019
    RaBjo , Nov 24, 2019 :
    +1 on turning of auto brightness. That function needs a lot of TLC.
    gjseth likes this.
  13. redford
    Eclair Nov 24, 2019
  14. sup3rbuck
    Cupcake Nov 25, 2019
    sup3rbuck , Nov 25, 2019 :
    phone is now 4 weeks old and auto brightness seems to work good.
    however, when night mode is activated it still gets too dark
  15. Jason_Kilo
    Cupcake Dec 5, 2019
    Jason_Kilo , Dec 5, 2019 :
    I also have this issue. I have a feeling that the one on the Android 9 was more responsive. Since the update, I need to manually turn it off and on to let the brightness change "automatically".
  16. RaBjo
    Froyo Dec 5, 2019
    RaBjo , via OnePlus 7T Pro , Dec 5, 2019 :
    Hate to breakit to you, but this is the OnePlus 7T Pro forum, not the 7 Pro forum.
  17. raitchi
    Donut Dec 5, 2019
    raitchi , Dec 5, 2019 :
    Same problem issue here - adaptive brightness is way to dark when lighting is low. Oneplus really need to resolve.
    Rondix91 likes this.
  18. sup3rbuck
    Cupcake Dec 5, 2019
    sup3rbuck , Dec 5, 2019 :
    I solved it.
    the option in OnePlus laboratory
    disabled the DC thing.
    it does something with the screen.
    #38
  19. redford
    Eclair Dec 6, 2019
    #39
  20. chrisjenx
    Cupcake Dec 7, 2019
    chrisjenx , Dec 7, 2019 :
    this is a problem on the 7 pro too. not sure how it's so bad. it's like they never tested it.
    #40
