auto focus took more than 2 minutes
  1. synclear
    Cupcake Mar 13, 2019
    synclear , Mar 13, 2019 :
    Hey, does anyone also facing the same problem that the autofocus of the camera takes more than 2 minutes to work? Please help...
  2. ghostofcain
    Marshmallow Mar 13, 2019
    ghostofcain , Mar 13, 2019 :
    Your camera module is failing, get it or your device replaced.
    dsmonteiro likes this.
  3. Liehjan
    Liehjan , Mar 13, 2019 :
    This is a know issue on 3t camera modules, you need a replacement to get it to work... The issue is hardware not software.
    ghostofcain likes this.
  4. AGuser
    Froyo Mar 13, 2019
    AGuser , Mar 13, 2019 :
    NO, this problem is a software, the MODULE works good, but takes time to focus much better on objects, for me it takes 30 seconds, it's annoying. When i use Gcam there is no issue, but the quality of pictures is different and sometimes i want to use stock camera.
  5. Paschfire
    KitKat Mar 14, 2019
    Paschfire , Mar 14, 2019 :
    The issue of the rear camera not focusing for a majority of 3/3T users 3 is not a SW problem, it is a known HW failure.
    The only fix for it, is having rear camera module replaced.
  6. AGuser
    Froyo Mar 14, 2019
    AGuser , Mar 14, 2019 :
    I know, what you are talking about. i have already answered on such issues, as you mentioned, but THIS topic is different. I can take good photos on stock camera, but to make small objects sharper, i have to wait for some time
  7. Paschfire
    KitKat Mar 14, 2019
    That's all part of the HW failure of the camera, only known fix to which is by having the rear camera module replaced.
  8. AGuser
    Froyo Mar 14, 2019
    Paschfire
    That's all part of the HW failure of the camera, only known fix to which is by having the rear camera module replaced.​
    Why don't you want to listen to me?) On Gcam there is no issue)
  9. Paschfire
    KitKat Mar 14, 2019
    I am listening, still though it's all the same issue.
    Gcam sometimes fixes focusing through image processing, not all the time though and usual the problem will get worse.
  10. G_Suraj_Shinde_NPNz
    Froyo Mar 14, 2019
    G_Suraj_Shinde_NPNz , Mar 14, 2019 :
    so every OP 3T user face same problem ?
  11. Liehjan
    Marshmallow Mar 14, 2019
    Liehjan , Mar 14, 2019 :
    Not every user, but many did... Oneplus even had a free camera module exchange program active last year
  12. EroGamer983
    Cupcake Mar 14, 2019
  13. Paschfire
    KitKat Mar 17, 2019
    Paschfire , Mar 17, 2019 :
    It's a widely reported and commonly known HW failure on the 3/3T, the rear camera loosing the ability to focus. Only becoming apparent after an update is nothing more than a unfortunate coincidence.
    The only solution is having the rear camera module replaced, best would be calling a OnePlus service center for a quote on possible repairs.
  14. ghostofcain
    Marshmallow Mar 17, 2019
    ghostofcain , Mar 17, 2019 :
    Fine roll back to a known good release and await a new update, please do keep us informed as to your results.
