Auto hide on screen buttons
  1. HBKGANG
    Honeycomb Nov 13, 2015
    HBKGANG , Nov 13, 2015 :
    Does anybody know how to auto hide on screen buttons? For example my old lg g3 had a setting where you can pick what apps will auto hide the on screen buttons. No root Screenshot_2015-09-26-17-53-33.png
    sunilbagalur likes this.
  2. imattv4
    Ice Cream Sandwich Nov 13, 2015
    awesomeX1 likes this.
  3. HBKGANG
    And those are?
  4. Taddel
    Donut Nov 13, 2015
    Bharath HT likes this.
  5. gmo8492
    Lollipop Nov 13, 2015
    gmo8492 , Nov 13, 2015 :
    Switch to superior capacitive buttons, or enable expanded desktop in settings.
  6. gmo8492
  7. Taddel
    Donut Nov 13, 2015
    Taddel , Nov 13, 2015 :
    GMD Immersive Mode
    Fist up is GMD Full Screen Immersive Mode. The developers of this app rose to prominence with a mod that provided similar functionality to Immersive Mode before that feature was even added to Android.
    Once installed, a notification widget will allow you to toggle between 3 soft key modes—the normal mode, hidden soft keys, or hidden soft keys and status bar. As with all Immersive Mode mods, you can simply swipe up from the bottom of the screen to temporarily bring back your soft keys.
    [1] Notification Widget, [2] Softkeys hidden, [3] Softkeys and status bar hidden
    If you'd like some help setting up GMD, be sure to check out Neil's full tutorial on the subject.
    Power Toggles
    If you'd rather have this functionality in a home screen widget, or if you'd simply prefer a notification widget with more functionality than GMD offers, Power Toggles is the way to go. This app is designed for giving you quick access to system functions like Wi-Fi and Bluetooth, but it can also be set up to quickly trigger Immersive Mode.
    [source: http://android.wonderhowto.com/insp...reclaim-precious-screen-real-estate-0162519/]
    gmo8492 likes this.
  8. Irenicusss
    Gingerbread Nov 29, 2017
    Irenicusss , Nov 29, 2017 :
    Thank you for GMD, I can finally hide those button on the home screen. Unfortunately the third option (hide low and high bar) doesn't work for me.
    I'm on Nova Launcher.
    Suggestion?
  9. pgomase
    pgomase , Nov 29, 2017 :
    Why are you using screen buttons when you have the option of capacitive buttons?
    Have you not read the manual for understanding of functions and features?
  10. Jardani
    KitKat Nov 30, 2017
    Jardani , Nov 30, 2017 :
    I was just going to say this.
