2
Auto Login in WiFi Captive Portal
  1. F_Anmol_DTRy Cupcake Jan 22, 2018
    F_Anmol_DTRy, Jan 22, 2018 :
    Hi,
    I'm a college student and I need to login in wifi everytime when I connect to WiFi. This irritates me so much. Can I except a feature in OnePlus by which it automatically log me in when I connect to wifi?
    Thanks
    Anmol
    pramantiwari and O1511348374175 like this.
  2. Deatham Ice Cream Sandwich Jan 22, 2018
    Deatham, Jan 22, 2018 :
    sadly, this can't be fixed by oneplus.
    this has nothing to do with the phone, it's your University that's causing this.
  3. Green_1 Gingerbread Jan 22, 2018
    Green_1, Jan 22, 2018 :
    Captive portals are the scourge of the earth, demanded by lawyers and marketing people, and liked by nobody. They cause all sorts of problems, and have no positive purpose. The best bet tends to be to simply not connect to networks that use them so that your phone won't lose its data connection simply because you walked by one. Of course that works better if you can secure a data plan that doesn't require you to constantly be on the lookout for wifi to avoid overage fees.
  4. pramantiwari Eclair Feb 21, 2019
  5. E1552873266408 Cupcake Apr 23, 2019
    E1552873266408, Apr 23, 2019 :
    I know people keep saying one plus can't fix this but they can. Samsung phones have the option of "open with Chrome" but my one plus 6t can't do that.
  6. Logancd1 Ice Cream Sandwich Apr 23, 2019
    Logancd1, Apr 23, 2019 :
    That's just a matter of default apps. Go into settings and search for "default"; you can change your default app for just about anything. Has nothing to do with Samsung vs OnePlus. You probably clicked on "Always" when that popup came up once and so now it's remembering to use a specific app every time.
  7. E1552873266408 Cupcake Apr 23, 2019
    you're incorrect my friend, I have set my default apps. Captive portals don't open with default browsers but I'm saying that in Samsung phones there is extra functionality that allows to launch default browsers from captive portals
