2
Auto rotate not working via OnePlus 7 Pro
  1. Dakshvarshneya , via OnePlus 7 Pro , Apr 23, 2021 :
    After updating my phone to oxygen os 11, the auto rotate screen has stopped working and screen just won't rotate.
    The setting is enabled however still the phone doesn't respond. Sometimes it does but 90% of the time it doesn't.
    Liza_Štumberger and AashishMdr like this.
  2. Insane_Butcher , via OnePlus 7 Pro Nebula Blue , Apr 23, 2021 :
    Try this. Hold the side power button until you get the power off screen. Touch and hold that (power off symbol) down until you get a "Reboot to Safe Mode". Hit OK. Once it's rebooted you're going to be in safe mode. Try your auto-rotate button and see if does work.
    Just reboot to get out of safe mode.
    sahilarora017 and Dakshvarshneya like this.
  3. Ragevenom50
    Cupcake Apr 23, 2021
    Ragevenom50 , Apr 23, 2021 :
    Hi, facing the same issue. I tested booting in safe mode. Auto rotate seems to work there. Tested using an image in gallery.
    McJader likes this.
  4. AdnanSk
  5. AdnanSk
    AdnanSk , via OnePlus 7 Pro , Apr 23, 2021 :
    It's working of mine
  6. Ragevenom50
  7. Ragevenom50
  8. kastor38
    Cupcake Apr 24, 2021
  9. rleopardsc
    Cupcake Apr 26, 2021
    rleopardsc , Apr 26, 2021 :
    I had the same problem after update to 11. Not sure why, but after I uninstalled Battery Doctor app, it began to work again. So it seems to be a power saving issue.
  10. #10
  11. AashishMdr
    Cupcake Apr 27, 2021
    Dakshvarshneya likes this.
  12. Artemus.
    Community Hero 2020 Apr 27, 2021
    Artemus. , Apr 27, 2021 :
    I'm gonna go out on a limb here and ask... does tapping "Rotate" on the bottom of the screen possibly rotate it?
    McJader and Tokolozi like this.
  13. K1569253959616
    Cupcake Apr 28, 2021
    K1569253959616 , via OnePlus 7 , Apr 28, 2021 :
    It happens after u put ur phone to charging once. Until you Restart it won't be fixed (temporarily).
    Even my games which work on landscape have started opening in Portrait mode...
  14. Tokolozi
    Most Original Avatar Apr 28, 2021
    Tokolozi , Apr 28, 2021 :
    Since you have the rotate button at the bottom, it means you have auto rotate turned off in the quick toggles/
    Artemus. likes this.
  15. O. Priya
    Honeycomb Apr 28, 2021
    O. Priya , Apr 28, 2021 :
    Some apps might not be supporting auto rotation. Still if you have problem, try clearing caches as your phone might be slow and taking time/response out for rotation
