3
Auto rotate not working
  1. brao
    Cupcake Aug 1, 2021
    brao , via OnePlus 7 Pro , Aug 1, 2021 :
    its temporary solution, it worked for me but after a day issue is back.
  2. T1568909311628
    Cupcake Aug 1, 2021
    T1568909311628 , via OnePlus 7 , Aug 1, 2021 :
    This is because of some 3rd party apps like clean master or battery saver apps which needs "Display over other apps" permission.
    Please do not enable this permission otherwise auto rotate will have issues again.
    Auto rotate will work fine till you give permissions to such apps.
    brao likes this.
  3. Z1629910133452
    Cupcake Aug 25, 2021
    Z1629910133452 , Aug 25, 2021 :
    Same issue. Plus low notification sound on text's, doesn't alert every x minutes. I regret buying this POS.
  4. 7.7atharva
    Cupcake Aug 27, 2021
    7.7atharva , via OnePlus 6 , Aug 27, 2021 :
    After the update the auto rotate doesn't work, the device has just become useless, doesn't feel the same.
    pubg never opens in potrait mode.
  5. 7.7atharva
    nope, its on yet the youtube app shows the rotate option, also that in app option also doesn't work.
  6. I1577362872388
    Cupcake Aug 28, 2021
  7. waynefontana
    Cupcake Oct 2, 2021
    waynefontana , Oct 2, 2021 :
    I have a Nord 2 running Oxygen 11.3 and I can't find 'reset app preferences'. Nothing is found if I search for that. Please help.
  8. M1536244081708 , via OnePlus 6 Midnight Black , Oct 9, 2021 :
    Thank you very much for your suggestion it worked perfectly with me, thanks again 👍👍👍👍👍
  9. G_piyush_patel_nAvk
    Cupcake Oct 15, 2021
  10. Z1633364391879
    Cupcake Nov 28, 2021
    Z1633364391879 , Nov 28, 2021 :
    Resetting apps works but is a pain to do all the time. The best solution...if you have the CleanMaster app. delete it and the problem goes away. I replaced CleanMaster with CC
  11. MARC_N
    Cupcake May 6, 2022
    MARC_N , May 6, 2022 :
    Thank you SO MUCH! My phone wasn't receiving messages on my status bar FOR MONTHS.
    Last night auto-rotate crapped out. My phone is back! Best.
