auto rotate not working
  1. Priyank20497
    Donut Mar 27, 2017
    Priyank20497 , Mar 27, 2017 :
    from 3 days auto rotate is not working I'm facing big difficulties due to same plz help me
  2. BobbyV8_
    The Showcase Reviewer Mar 27, 2017
  3. BobbyV8_
    BobbyV8_ , Mar 27, 2017 :
    Ok, as for the solution, tell me what have you tried to fix the issue first
  4. tbalnt
    Ice Cream Sandwich Mar 27, 2017
  5. BobbyV8_
    Oh god! clearing cache wont work for hardware issues dude.
    restart the mobile with auto rotate ON
    doesn't work?
    check the sensors with Check My Android to see which sensor is causing it so that we can go further to fix it
  6. tbalnt
    tbalnt , Mar 27, 2017 :
    not 100% it is a hardware issue. You can have such bugs after installing certain apps from the junk left behind. I was like this several times on samsung. after factory reset it was ok. Then would have came a service.
  7. blueblarog
    Cupcake Mar 28, 2017
  8. G_Chris_Murphy_ymNT
    Eclair Mar 28, 2017
