_Vishwa_Shyam_ , via OnePlus 8 , Nov 26, 2020 : While Playing YouTube or any websites vedios even auto rotation is locked it doesn't come to potrait it still plays on wide screen
DenzilRitesh , via OnePlus 8 Pro , Nov 26, 2020 : I'm facing the same issue, is it a youtube or oneplus issue?
qifka , via OnePlus 8 Pro , Nov 26, 2020 : Definitely a OnePlus issue. Checked on several android phones, they work as intended, but on OnePlus I have this problem too.
Saucy78 , via OnePlus 8 Pro , Dec 4, 2020 : If you notice when you change the orientation of the screen.. a small icon appears at the bottom. Touching that allows you to change the orientation back to Portrait.. Keep an eye at the bottom of the screen for this icon.
Ajin_Grace_Thomas , via OnePlus 8 , Dec 4, 2020 : I have this same problem... before youtube used to automatically go to portrait once I exit from the fullscreen mode . Now it just gets locked in landscape instead of switching to portrait
Saucy78 , via OnePlus 8 Pro , Dec 4, 2020 : If you notice when you change the orientation of the screen.. a small icon appears at the bottom. Touching that allows you to change the orientation back to Portrait.. Keep an eye at the bottom of the screen for this icon. View attachment 1503965
Ajin_Grace_Thomas , via OnePlus 8 , Dec 4, 2020 : But why would they change an useful feature for this
Saucy78 , via OnePlus 8 Pro , Dec 4, 2020 : I find this quite an interesting function as it gives the user the choice to move between landscape and portrait but quickly . I have had situations when I was watching content lying down and the orientation was not the way I wanted.
akkipatel95 , via OnePlus 8 , Dec 4, 2020 : True. But it's a workaround for now. It appears everytime when your screen rotates. So. It's not a solution. It is a feature for those who don't want to change screen to landscape mode everytime. It's useful when they only want to rotate screen in specific app.
akkipatel95 , via OnePlus 8 , Dec 4, 2020 : It's the problem with OnePlus update. Hope they fix it in next update.
SyedYaseenOP8 , via OnePlus 8 , Dec 4, 2020 : Yes you have to check for it and touch once to get back to your normal or portrait mode or full screen mode. I have been seeming this icon on my dive for some time now.
