Auto Sleep issue via OnePlus 8T
  1. genies90
    Cupcake Jan 27, 2021
    genies90 , via OnePlus 8T , Jan 27, 2021 :
    Hello, I've enabled auto Sleep feature on my phone. But it doesn't work most of the time leaving my phone's battery draining for hours. I'm experiencing this frequently and kindly let me know if there's any fix available. Thanks.
  2. camohan
    Assistant Head Moderator Assistant Head Moderator Jan 27, 2021
    camohan , Jan 27, 2021 :
    Hi there, what is your settings under display, sleep?
  3. genies90
  4. camohan
    Ok. So do you mean the screen never sleeps after 1 minute of inactivity?
    Or you see the screen not sleeping while in charging?
  5. genies90
    Yes. It stays on until I lock it manually.
  6. Tokolozi
    Most Original Avatar Jan 27, 2021
    Tokolozi , Jan 27, 2021 :
    Even on the homescreen, some apps might keep your device awake then.
  7. DaLuigeVinci
    Cupcake Mar 20, 2021
    DaLuigeVinci , via OnePlus 7 Pro , Mar 20, 2021 :
    I'm having the same issue. Even with no apps running in the background the phone continues to do this.
  8. mynulislamm
    Cupcake Oct 24, 2021
    mynulislamm , Oct 24, 2021 :
  9. GuiZ
    Donut Oct 25, 2021
  10. joemxavv
    Cupcake Nov 10, 2021
