Auto start Bluetooth and vpn sometimes and doesn't want to stop from quick setting.
  1. G_Mere_Puff_dalc Froyo Mar 13, 2018
    G_Mere_Puff_dalc, Mar 13, 2018 :
    hi there, in my OP5 stable version 5.0.4 I'm facing some problem like Auto start Bluetooth and vpn and it doesn't want to stop from quick setting. another problem is when someone call me on meseenger my phone vibrate and won't stop vibrate after receiving or cancel the call (not always but sometimes). Am I the only one facing the problem?
  2. Eustacio Sealy Ice Cream Sandwich Mar 14, 2018
    Eustacio Sealy, Mar 14, 2018 :
    Good night sorry to see the issues you have reported but it seems that you are the only one with these issues
  3. Paweł P Cupcake Mar 14, 2018
    G_Mere_Puff_dalc likes this.
  4. Segaco Donut Apr 22, 2018
    Segaco, Apr 22, 2018 :
    In my opinion, it's a software problem that could be resolved via a factory reset.
    I would suggest to first backup the essentials and run a thorough wiping of your cache partition.
    If the problem persists, consider a factory reset and removing the current VPNs you may have (which could be causing the problem as they are just not compatible with your current version).
    If you need recommendations for better ones, here're a couple.
