Automatically Going To Aeroplane mode While in Call?
  1. Dinu6
    Gingerbread Feb 8, 2017
    Dinu6 , Feb 8, 2017 :
    I think this is a proximity sensor issue because while i am in call the notification switches are automatically accessed for example: Aeroplane mode,NFC,etc...
  2. Dinu6
  3. Dinu6
  4. diptajit.paul
    Froyo Feb 8, 2017
    diptajit.paul , Feb 8, 2017 :
    Have you updated your device to Nougat? Proximity sensor issue was there prior to Nougat but this have been taken care off in Nougate.If you have not update ur device, please update and the issue will be resolved.
  5. vikeor
    vikeor , Feb 8, 2017 :
    First of all... no need to post 3 times in 2 minutes.
    Have you tried resetting your device? And update it as it was suggested above.
    Francisco88 likes this.
  6. murukesh
    Cupcake Feb 8, 2017
  7. Dinu6
    Gingerbread Feb 9, 2017
  8. saurabhparwal
    Froyo Feb 9, 2017
    saurabhparwal , Feb 9, 2017 :
    I'm on Oxygen OS 4.0.2 Resetted the device, cleared cache under recovery mode but still proximity Sensor problem not solved?
  9. tiwariankit
    tiwariankit , Feb 9, 2017 :
    I think any app is responsible for this.
    Check permissions of all your apps.
    Remove permissions for network and cross check the problem.
    I did same when my friend was facing same issue and finally the issue was solved
  10. Dinu6
    Gingerbread Feb 11, 2017
  11. banditknight
    Honeycomb Feb 11, 2017
    banditknight , Feb 11, 2017 :
    It's the crappy dialer of OnePlus. I learned I need to wait a second before putting the phone against my ear. Otherwise it happens that the screen does not dim and random UI elements get activated. Several times it happened to me that airplane mode got activated.
    Dinu6 likes this.
