autorotation of calculator application even when it is portrait mode
  1. sumitkawate
    Cupcake Sep 2, 2018
    sumitkawate , Sep 2, 2018 :
    I'm facing an issue as autorotation of calculator application even when it is portrait mode or landscape mode. It is from when i purchased my phone. also attaching some pics.
    kindly fix the issue..
    kylesare57 likes this.
  2. camohan
    Moderator Moderator Sep 2, 2018
    camohan , Sep 2, 2018 :
    This is not an issue, it is the stock behaviour of the stock calculator app.
    elanglois likes this.
  3. sumitkawate
    Cupcake Sep 2, 2018
    any fix??
  4. kylesare57
    Eclair Sep 2, 2018
  5. sumitkawate
    Cupcake Sep 2, 2018
  6. camohan
    Thats how it is in google phones too. Fix is to use some other calc app from playstore.
  7. sumitkawate
    Cupcake Sep 2, 2018
    but that's not actual fix .. developers should take action on this... its very minor change in the code...
  8. Prcko
    KitKat Sep 2, 2018
    Prcko , Sep 2, 2018 :
    Yes its very minor change in code so you can make it
  9. sumitkawate
    Cupcake Sep 2, 2018
    yes sure love to do it.. :)
  10. Blue-agila
    Ice Cream Sandwich Sep 2, 2018
    Blue-agila , Sep 2, 2018 :
    So it will go to the back of the queue behind the major changes to the code. Get real!!!
  11. elanglois
    Lollipop Sep 2, 2018
    elanglois , Sep 2, 2018 :
    No. Developers should NOT. Quit bitching. It was designed that way. It's intentional. If you don't like it, use something else.
    xnutzii, Prcko and TheRealGamer like this.
