5
awesome battery life after 4.0.3 update highly satisfied
  1. F_Imtiaz_Fahad_Badhan_vm
    Froyo Mar 9, 2017
    F_Imtiaz_Fahad_Badhan_vm , Mar 9, 2017 :
    After the update 4.0.3 and charging it for 2/3 cycles, the battery life has become so good even while heavy usage. I've played games straight 3 hours, wifi was on all the time, surfing net watching youtube, messenger was always on, still got 8 hours of S.O.T while 21% charge was left. It's very satisfactory [e]1f60d[/e][e]1f60d[/e]
  2. AHMED__7
    Cupcake Mar 9, 2017
    lucah likes this.
  3. rahul_jain98
    Eclair Mar 9, 2017
  4. F_Imtiaz_Fahad_Badhan_vm
    Froyo Mar 9, 2017
    Trust me 4.0.3 is better than 3.5.4 battery backup. I hard reset my phone and cleared cache right after the update try it dude
    G_Mr_.... and Deactivated User like this.
  5. danyboy1234
    Honeycomb Mar 9, 2017
  6. shubham096
    Eclair Mar 9, 2017
    dbau071101 likes this.
  7. darius1988
    KitKat Mar 9, 2017
    darius1988 , Mar 9, 2017 :
    At the first me to , after 2 weeks the batterry start drain, the phone is lagging, wifi drop...
  8. Krishnasoujith25
    Froyo Mar 9, 2017
    Krishnasoujith25 , Mar 9, 2017 :
    Off smart wifi and other stuff in wifi settings ur battery life would be back plz like my solution so that i could help other people if the problem is solved with the oneplus
    darius1988 likes this.
  9. Krishnasoujith25
    Froyo Mar 9, 2017
    Off smart wifi and other stuff in wifi settings ur battery life would be back plz like my solution so that i could help other people if the problem is solved with the oneplus 3 4.0.3
  10. darius1988
    KitKat Mar 9, 2017
    You can post some screenshot of how you have wifi set , I tried disable ipv 6 but It give me issues compatibily with router, I tried set 2,4 GHz band and turn of automatic , It seems a liltle more stable but not to much, so yesterday I had done Factory reset because the phone was turned really laggy , and Today seems work better , but still drain 6% batterry over night and I don't have instal only wassap and Viki movie...
  11. Krishnasoujith25
    Froyo Mar 9, 2017
    Here it is
  12. crajat22
    Cupcake Mar 9, 2017
  13. priyam678
    Cupcake Mar 9, 2017
  14. lockhartz
    Donut Mar 9, 2017
  15. G_GAUTHAM_RAVI_dGnC
    Gingerbread Mar 9, 2017
    G_GAUTHAM_RAVI_dGnC , Mar 9, 2017 :
    i have seen your screen shot...in that you have not inserted sim.so it wont pull much battery....thats the reason u r getting 8hrs of SOT...insert the sim and use it u could find the difference
  16. paidavera
    Froyo Mar 13, 2017
    paidavera , Mar 13, 2017 :
    Did you make any phonecalls?..
