Awful battery life
  1. dylinidle375
    Froyo Aug 19, 2015
    dylinidle375 , Aug 19, 2015 :
    Lately my OPO's battery life has absolutely tanked. Even with a wide variety of kernel tweaks and greenify mods my phone can barely push 3 hours SOT and 12 hours off charge. Yes I know most of you will say to switch back to KitKat, but even that produces maybe 3.5 hours at best with all the tweaks. Another argument is multirom but even if I install it as my internal my battery life continues to be awful. I can't have this type of battery life when I'm back in school and away from home for many hours at a time. Might be time for an upgrade.
  2. matthewtaylor1995
    Honeycomb Aug 19, 2015
  3. Heisenberg1984
    Ice Cream Sandwich Aug 19, 2015
  4. 7s29
    Gingerbread Aug 19, 2015
    7s29 , Aug 19, 2015 :
    Wow ! That battery life is shocking. I'm getting 2 days out of mine, and one day on heavy use.
    Check your apps, keep awake, search for WiFi. I made sure these things won't drain my battery, so far so good, and good luck.
    Tepi and crazycarl like this.
  5. Lif3less
    Lif3less , Aug 19, 2015 :
    Getting 24 hours with atleast 3 hours of SoT with medium/heavy usage. Like suggested, check your battery health. Also take a look at which apps are running in the background.
  6. scottrc
    Eclair Aug 19, 2015
    scottrc , Aug 19, 2015 :
    If you haven't already, try turning on auto-brightness. The screen is the major drainer so having it automatically drop the brightness to like 20-30% when it is not needed is a good way to save battery.
    Tepi likes this.
  7. TheManDroid
    TheManDroid , Aug 19, 2015 :
    Can you post some battery stats?
  8. lywingging
    Froyo Aug 19, 2015
  9. yhtan3001
    vaibhav_diamond likes this.
  10. Tiger Bred
  11. crazycarl
    crazycarl , Aug 19, 2015 :
    In roughly the same boat as you I have owned my OPO for just over a year and I still get about 2 days of battery life.. Mind you I am still on CM11 and never upgraded past this as I heard nothing but horror stories.. There are steps to see what the issue is but you may want to look at replacement for the battery
  12. vaibhav_diamond
    yhtan3001 likes this.
  13. sjketchen
    sjketchen , Aug 19, 2015 :
    You may have the Google Play Services wake lock problem. I had problems with battery life on my OPO since CM11S R33 OTA update. This is the only fix that worked for me.
    http://forum.xda-developers.com/one...mod-google-play-services-update-wake-t3078082
    This still didn't fully fix the battery drain problems, but it did improve them significantly. I dumped my OPO for an Alcatel OneTouch Idol 3 back in May and it was the best choice I made. Much better and more stable battery life than my OnePlus One ever had.
  14. nishantace
  15. jakereed
    jakereed , Aug 19, 2015 :
    Maybe irrelevant but on my g3 i'm lucky to get 1hr 30 SOT...I think I may need a replacement battery ;)
  16. Tepi
    Tepi , Aug 19, 2015 :
    Go to swim with Your OPO, after that You don't think any battery problem...
  17. SKHD
    Eclair Aug 19, 2015
    SKHD , Aug 19, 2015 :
    I am actually excited for the new battery.. you talked about the old opo battery. The new one is about 3000mAH? My phone (galaxy s4 mini)´has like what? 1900mAH? And with this I get around the whole day even with my usage! I mainly use it as an hotspot for my iPod! :D
  18. ankitjain88
    Froyo Aug 19, 2015
