backup problem
  1. shiv_21
    Cupcake Aug 16, 2019
    shiv_21 , Aug 16, 2019 :
    Hi guys ,
    there was some small issues with my OP5 so I went to service centre they said we need to format the device so I agreed but I forgot to see that I had taken the backup of my notes so is there a way I can get that data back? . any help is appreciated.
  2. Malg220
    Honeycomb Aug 16, 2019
    Malg220 , Aug 16, 2019 :
    No, unfortunately, the apps that recover data only focus on Photos, Videos, Audio
  3. Horsault
    Marshmallow Moderator Aug 16, 2019
    Horsault , Aug 16, 2019 :
    If you backed up using Switch (and saved the file on another disk), your notes should be saved.
  4. shiv_21
    Cupcake Aug 19, 2019
    shiv_21 , Aug 19, 2019 :
    actually if you see there is no settinga option through which you can select the option to save it on drive so I should directly get saved somewhere . example we don't have to save the google sheet it saves automatically. so is there anything we can do?
  5. Horsault
    Marshmallow Moderator Aug 19, 2019
    Horsault , Aug 19, 2019 :
    The difference is, your Google docs aren't saved on your device at all. They're only stored on your Google account, analysed, as well as each and every type and location, and stored for selling your data.
    OnePlus Notes is an offline app.
  6. shiv_21
    It means I am in a mess.
    Anyways thanks for helping guys really appreciate it.
  7. Horsault
    As you still didn't tell us what you used to backup your device, we won't be able to help more.
