3
ROM [BACON][UNOFFICIAL] Dirty Unicorns PURE [AOSP]
  1. Pahapoika91
    Ice Cream Sandwich Jun 9, 2016
    Pahapoika91 , Jun 9, 2016 :
    Good night @ngengs
    I can test your beta or alpha versions.
    I would like to see 3-features.
    Doze, ambient screen when hand is near and option to add more titles to quick settings bar.
    (That ambient screen would be like theres in oxygenos)
  2. Pahapoika91
    Ice Cream Sandwich Jun 10, 2016
  3. ngengs
    Honeycomb Jun 10, 2016
    ngengs , Jun 10, 2016 :
    I use f2fs in data and cache with this rom
    Btw about your request...
    doze is here, its default in marshmallow right? in battery>three dot, battery optimization
    ambient like oxygen... I dont like that, with that will drain your battery...
    add titles? or add tiles? I dont really understand, add tiles is here. add titles? what titles?
  4. Pahapoika91
    Pahapoika91 , Jun 10, 2016 :
    Can you then optimize doze?
    Overnight drain ~20%.
    In oxygenos ambent display when hand is near uses hexagon dps so it doesnt drain much battery.
    I mean quicksetting bar (when you pull down 2-times.) that could be like its in cm13.
    Etc in cm13 you can add tile that lets you control screen timeout without opening all settings.
    Edit: got that small lag between home button press and action even in google now launcher.
  5. ngengs
    what apps is draining your battery in night? can you check it?
    I dont know its good to implement that, but I dont like that feature when I use oxygen.
    Do you really check DU-Tweaks? Add quick tiles is there bro, screen timeout, volume panel and other quick setting can you pick in DU-Tweaks...
  6. Pahapoika91
  7. ngengs
    New build is up: Download
    Like I said before this build will:
    - test voltage control, in my device is dont have problem.
    - test sound control to in kernel
    and now DU version is v10.3 (have screenshot crop & share, pulse bar config, etc)
    Include June security patch
    Updater via AFH
    Show PURE changelog in DU-Changelog
    etc...
    Changelog
    blinoff82 and Disx like this.
  8. Disx
    Ice Cream Sandwich Jun 11, 2016
    Disx , Jun 11, 2016 :
    Nice job! Thanks
    ngengs likes this.
  9. hellcat50
    Froyo Jun 11, 2016
    ngengs likes this.
  10. ngengs
    Honeycomb Jun 11, 2016
    ngengs , Jun 11, 2016 :
    You are welcome bro,
    thanks to using this rom :)
  11. arvindautar
    Eclair Jun 11, 2016
    arvindautar , Jun 11, 2016 :
    Hi can you do anything about the camera blobs used? Using sultan´s or color os blobs would make this rom more whole.
  12. ngengs
    Honeycomb Jun 12, 2016
    ngengs , Jun 12, 2016 :
    Sorry for now I dont want to do that, personally I dont really like that camera blob.
    But maybe someday I change my mind, I will info here if i want to do that.
    Thanks for your suggestion.
  13. mpaopao
    Cupcake Jun 12, 2016
    mpaopao , Jun 12, 2016 :
    Anyone has problem with wifi saved password? Have to put password everytime when switching wifi ssid ,even with the last ssid.
  14. ngengs
    I have 2 ssid in home and dont have problems just input password once when first connect.
    Can you give me logcat?
  15. mpaopao
    Switching between 2 ssid.
  16. ngengs
    Wow you right, it has problem with manually change ssid
    before you said that my ssid 2 is outside range of ssid 1 and auto connect,
    if change manually within ssid I must input password,
    I will look at your logcat this night
    mpaopao likes this.
  17. ngengs
    Honeycomb Jun 13, 2016
    ngengs , Jun 13, 2016 :
    Tried other rom based on DU, latest weekly and other rom based on bacon DU its has bug manual changed ssid...
    Damns its DU bug?
    Looking at setting source, but nothing wrong with the logic.
    Still searching the source of problems.
    Sorry @mpaopao
    mpaopao likes this.
  18. Disx
    Ice Cream Sandwich Jun 17, 2016
    Disx , Jun 17, 2016 :
    I try a lot of roms but I always come back to DU, it's the best :D
    #38
    ngengs likes this.
  19. ngengs
    Honeycomb Jun 18, 2016
    ngengs , Jun 18, 2016 :
    Thanks bro
    I'm happy you love the unicorns ;)
    #39
  20. ngengs
    Sorry guys, I messed up with updater API in github raw
    I dont know if this afternoon the update will show to you via updater, but yeah today I will deliver the update.
    what change in this update,
    I upgrade kernel to 3.4.112 and some other tweaks in kernel,
    fix bug with lockscreen (menu key automatically open the lockscreen),
    fix updater API,
    screenshot crop & share add pen width option,
    and... I forgot what I change, LOL.
    But of course it sync with latest update from DU.
    #40
    blinoff82 likes this.
