Bad audio quality while recording video from front camera
  1. P1557924867330
    Cupcake Apr 14, 2020
    P1557924867330 , Apr 14, 2020 :
    I have suffered from this issue from the beginning. when I record video from front camera the audio quality is bad and tinned and distorted. it seems like it uses noise cancelling microphone for recording. it also happens with Facebook live and other third party apps while using front camera. but when I record with back camera on, the audio quality is fine. Has One plus fixed this issue or does anyone have a solution to fix this.
  2. reyl
    Cupcake Jun 2, 2020
    reyl , Jun 2, 2020 :
    looks like they are not doing anything regarding this issue.
  3. Caomhin
    Lollipop Jun 2, 2020
    Caomhin , via OnePlus 6T , Jun 2, 2020 :
    Try Clearing Camera App info Cache and App info Storage. See if that helps.
    Also try a GCam and compare to see if the different camera software cause the same issue or not, to see if its software or hardware issue.
    Dev Marco Gcam integrated XML files for 6 series phones.
    I have this one installed and it works very well.
    7.3_GCam_MJL_v4.1.1_Minilux.apk (marco, 2020-04-29, oneplus 6/6t, changelog)
    The XML are integrated, so no additional files required.
    https://www.celsoazevedo.com/files/android/google-camera/dev-marco/
    Artemus. likes this.
  4. JATINOSTWAL
    Cupcake Jun 3, 2020
    JATINOSTWAL , via OnePlus 6 , Jun 3, 2020 :
    i also have the same issue with one plus 6. front camera mic is not audible but no issues with other apps. audio is clear with other apps like watsapp calling and other camera apps.
  5. Caomhin
    Lollipop Jun 3, 2020
    Caomhin , via OnePlus 6T , Jun 3, 2020 :
    Have you tried the steps I suggested above?
  6. JATINOSTWAL
    Cupcake Jun 10, 2020
  7. Caomhin
    Lollipop Jun 10, 2020
