Camera Bad behavior of HDR indoors with artificial light in one plus 7 pro
  1. Nhas81
    Eclair Jun 13, 2019
    Nhas81 , Jun 13, 2019 :
    Please guys of one plus review the behavior of HDR in artificial light situations as it does a very bad job. It is impossible to take a decent photo with artificial light due to HDR.
  2. Discostu
    Jelly Bean Jun 13, 2019
    Bouncer71 likes this.
  3. Nhas81
    Eclair Jun 13, 2019
    [QUOTE = "Discostu, post: 20423353, miembro: 586602"] Puedes desactivar HDR [/ QUOTE]
    Yes of course I can but it is not a solution because if we have an automatic HDR the correct thing is to do it alone and to determine well the situation where you have to activate it. My comment is for people to report this same problem and the one plus guys give solution.
  4. Discostu
    Jelly Bean Jun 14, 2019
    Discostu , Jun 14, 2019 :
    HDR automatically turns on if it detects a scene with a dynamic range that is greater than one exposure can handle, so regardless of whether you are indoor or outside - if it is turned on and the scene warrants it, the phone will use HDR.
    Just switch it off at the times you find it troublesome.
