Banking apps on android
  1. Markj99
    Gingerbread Jan 7, 2015
    Markj99 , Jan 7, 2015 :
    Hi all, a quick question re using banking apps in UK.
    I had a nexus 4 and would do certain online banking transactions using my phone. Once I rooted it, these apps would no longer work.
    As the one+1 uses CM, does this mean the phone is classed as being rooted and subsequently UK banking apps won't work on it?
    Sorry in advance if this is on the wrong forum or already been posted☺
    nikunjchugh likes this.
  2. nunopinho1982
    Lollipop Jan 7, 2015
    Markj99 likes this.
  3. Jamzieth
    Ice Cream Sandwich Jan 7, 2015
    Markj99 likes this.
  4. nikunjchugh
    Honeycomb Jan 7, 2015
    Markj99 likes this.
  5. j0hnby
    Froyo Jan 7, 2015
    j0hnby , Jan 7, 2015 :
    Using CM doesn't mean you are rooted, unless you root it.......I have used the First Direct, Capital One and Lloyds apps on rooted phones with no problems though.
    chrisjeffery93 and Markj99 like this.
  6. Aaroneloy21
    Jelly Bean Jan 7, 2015
    Markj99 likes this.
  7. SugaDew
    Markj99 likes this.
  8. redleema
    KitKat Jan 7, 2015
    redleema , Jan 7, 2015 :
    Barclays won't work when rooted but there's a workaround I've yet to try.
    Markj99 likes this.
  9. Markj99
    Thanks all. Much appreciated.
    I had no intention of rooting the one+1 purely on the basis that I need my Barclay's app to work.
    Used to get message on nexus 4 "Barclay's online banking will not work on rooted devices".
    If the one+1 isn't rooted/boot loader still in tact, then the all should be fine... Have I understood this correctly guys???
    j0hnby likes this.
  10. Prey521
    Prey521 , Jan 7, 2015 :
    Installed the Xposed app and then install RootCloak from within Xposed. That app allows you to mask the root access from any apps you specify. This is assuming you're using a KitKat ROM, since Xposed does not work with Lollipop yet.
    Markj99 likes this.
  11. redleema
    KitKat Jan 7, 2015
    Forgot to mention in my last post that I've tried that but still no joy with Barclays.
    Markj99 likes this.
  12. redleema
    KitKat Jan 7, 2015
    Yes.
    j0hnby and Markj99 like this.
  13. 9843823790849
  14. Markj99
    Thanks all. Great help as per usual
    Will leave you all to get back to restoration man
  15. adm770
  16. elsa-nl
  17. j0hnby
    Froyo Jan 7, 2015
    Restoration Man: This couple of bonkers....two kids being born while the house is being done! It's looking lovely though.
  18. andyinthailand
  19. harry.anderson
    Cupcake Jan 7, 2015
  20. chrisjeffery93
