Battary drain fix ( Android System )
  1. omar2003
    Eclair Apr 24, 2015
  2. Jidhin George
    Gingerbread Jun 3, 2015
  3. Scarf_Ace
    Cupcake Aug 31, 2015
    Scarf_Ace , Aug 31, 2015 :
    Hey,
    Last evening I've had a system update of 318MB.
    it finished fine and after another restart I've Charged my phone to 100%.
    it was on Airplane mode from 24:00 to 7:00.
    When I woke up today the battery level was down to 92.6 hours later its at 61% without much use of the phone.
    In addition - when i check "Battery" under "Settings" it appears like only 25% were consumed by some apps. isnt it supposed to be equal to the real-time usage?
    (meaning if I see 61% battery, i should also see 39% battery usage by certain apps)Seems like some mysterious service is consuming my Battery... HELP!
    thanks in advance.
