batter issue
  1. Shaher_N_Shuvo
    Gingerbread Sep 1, 2017
  2. raveno123
    Ice Cream Sandwich Sep 1, 2017
  3. Tooony
    Tooony , Sep 1, 2017 :
    Is the batter too runny? You shouldn't add too much water just maybe a cup of water will do. You could try and add more flour though. Then try dip your fish in it before frying it!
  4. Shaher_N_Shuvo
  5. Shaher_N_Shuvo
    Shaher_N_Shuvo , Sep 1, 2017 :
    Hei I don't understand what are you talking about
  6. raveno123
    G_Manzoor_Ahmed_xkqv likes this.
  7. Shaher_N_Shuvo
    Bro it passed 4+hrs
  8. raveno123
    raveno123 , Sep 1, 2017 :
    you've been on your phone almost 14hours in one day
  9. Shaher_N_Shuvo
    I charged my phone 2 and half hours ago
  10. raveno123
    wipe the cache in recovery if that doesn't work a factory reset might
  11. Scorpion_2503
    Scorpion_2503 , Sep 1, 2017 :
    Read well. The approximated percent of battery usage is from last full charge... So I think it's normal having high percentage. Try to charge the phone 10%-100% and all will be fixed in my opinion
  12. darius1988
    KitKat Sep 1, 2017
    darius1988 , Sep 1, 2017 :
    You used the phone 30 hours , you charged 5 times, you have 14 hours sot. Now remember that because you charged under 90% the battery graphic will be merged with the previos , so that's why all this numbers (%) look bigger.
    Now , if you really have some problem with battery, charge the phone 100 %, than used normal until 15%, now with 15 % take few screenshots and than post. Tell us which phone/software/ when the battery drain/ what you do to solve the problem, give us details.
    ghostofcain likes this.
