3
Battery 94% - 5 Hrs left... ???
  1. vincentip
    Eclair May 14, 2015
    vincentip , May 14, 2015 :
    After upgrading to Lollipop, my battery life has been atrocious. It's not constantly awake like many others are having problems with, but instead it drains really fast when I'm actually using the phone. I'll end up with 2 hours screen on time and 15% before the day ends. I don't understand this.. and it seems that the phone gets hotter than it used to when doing regular tasks. If anyone has insight to this, please help. Thank you very much!
    ThijsOne+1, K1K3_123 and Target 33 like this.
  2. gusuraman
    Global Head Moderator May 14, 2015
    Target 33 likes this.
  3. Target 33
    Lollipop May 14, 2015
    Target 33 , May 14, 2015 :
    Don't worry @Carl is going to fix this soon. In the meanwhile try Privacy Guard to disable the service which cause battery drain.
    If that doesn't fix you can order a couple of powerbanks, OP will say thanks!
  4. LostPorcupine
    KitKat May 14, 2015
    npt and FXA like this.
  5. vincentip
    Eclair May 14, 2015
    Thanks for your reply, but it's Android System and OS that is on top of the list at the moment. I can't disable that, or else my phone won't function properly right?
    And... needing to buy powerbanks and spending more money on the company.. almost makes it seem like they did this on purpose... I won't give in :(
    Chugz and Min Khooptong like this.
  6. Vistro
    Gingerbread May 14, 2015
    Vistro , May 14, 2015 :
    For me, 6 hour+ of SOT is common. Try disable google play services,turn mobile network when wifi available, use greenify and uninstall fb messenger as it eat battery like breakfast,of a bodybuilder.
  7. LostPorcupine
    KitKat May 14, 2015
    LostPorcupine , May 14, 2015 :
    Don't disable the service itself, but disable it's ability to force a wakelock. A few people get serious issues and have to turn it back on, a few have no issues, and the majority will get very minor issues (I got an occasional, if not annoying, error while using Google Maps. Otherwise, there was no issue and Maps would still work).
  8. kart180
    Cupcake May 14, 2015
  9. FXA
    Ice Cream Sandwich May 14, 2015
    FXA , May 14, 2015 :
    You can install a Custom Rom, maybe Exodus.
    It gave me a much better battery life than Cyanogen OS 12
  10. Lingering
    Lingering , May 14, 2015 :
    Have you done the play services fixes like wakelock?
  11. Carlosfer
    Carlosfer , May 14, 2015 :
    Mine seems to be the same too. Like everything for this phones, it's a matter of luck.
    gusuraman likes this.
  12. Utkarsh verma
    Froyo May 14, 2015
    Utkarsh verma , May 14, 2015 :
    Try other rom i would say try broken os based on 5.1. ... The reason u will find in pics below... Screenshot_2015-05-14-13-37-47.png Screenshot_2015-05-11-01-38-59.png Screenshot_2015-05-11-01-38-56.png Screenshot_2015-05-11-01-38-49.png
  13. rez1_k
    rez1_k , May 14, 2015 :
    Which Lollipop build are you using and what process did you use to flash the ROM?
  14. vincentip
    Eclair May 14, 2015
    Thanks, but I want to stay stock if possible to avoid the custom roms >.< I'm not good with that stuff.
    Yes I have!
    Its stock - YNG1TAS17L
    Android 5.0.2
  15. fedonis
    Marshmallow May 14, 2015
    fedonis , May 14, 2015 :
    Quote
    @Carl is the light!
  16. roor7
    Honeycomb May 14, 2015
    roor7 , May 14, 2015 :
    The first thing
    If you charge you phone up to 100% and use it for 10 min as example:
    The phone will show you how long you can use it in this way (screen on, etc)
    So 5 h SOT
    Better you show us a pic of about 10 percent that we can see which apps are keeping the phone awake
    Just try a wakelock detector app
    The second
    What helped for my phone:
    Deactivate all the google stuff like G+
    I uninstalled them with this app (root required)
    https://play.google.com/store/apps/details?id=com.jumobile.manager.systemapp
  17. Wishmaster
    Wishmaster , May 14, 2015 :
    strange, for me theres no Android system or os drain but result on SOT is same as this guy mentions, well i don`t interested in system prophecies either but... ehm
    Chugz likes this.
  18. roor7
  19. tyushk
    Donut May 14, 2015
    tyushk , May 14, 2015 :
    I dont know what is happening but i just have improved batterie life.
  20. joseangelconejo
    Froyo May 14, 2015
    Henry80 likes this.
