3
Battery 94% - 5 Hrs left... ???
  1. blujadajhdja
    Ice Cream Sandwich May 14, 2015
    blujadajhdja , May 14, 2015 :
    Have you tried clearing cache in the recovery screen yet?
    I'm completely stock on latest COS 12 and mine gets 6 hours of SOT and sometimes a little more if I don't listen to music too much.
  2. mad-scientist
    Gingerbread May 14, 2015
    joaon likes this.
  3. locklear308
    locklear308 , May 14, 2015 :
    Looks about right, just switch back to 44s man. Lollipop has all kinds of audio bugs
  4. vjuricic
    vjuricic , May 14, 2015 :
    Powerbanks are nice and have good price, but shipment is unreasonable. :p
    Chugz and Target 33 like this.
  5. Utkarsh verma
    Froyo May 15, 2015
    roor7 likes this.
  6. vincentip
    Eclair May 16, 2015
    vincentip , May 16, 2015 :
    Hey, how do I clear the cache in the recovery screen? And what does that do exactly, would I lose any information?
  7. cedalone
    Jelly Bean May 16, 2015
    cedalone , May 16, 2015 :
    An other thread for nothing. How can you tell anything about battery life when you've just flash a new rom. Try to use your phone for more than a day, charge it a few times, and come back if your phone has a battery drain....imo
  8. blujadajhdja
    Ice Cream Sandwich May 16, 2015
    blujadajhdja , May 16, 2015 :
    Turn off the phone and hold down power + volume down. Wipe the cache partition. This doesn't clear any data, it clears the android system's cache (which is what you're usually supposed to do after big updates, such as going from Kitkat to Lollipop). Just be sure not to click on Wipe Data.
  9. walt.serg
    Eclair May 16, 2015
    walt.serg , May 16, 2015 :
    This problem is due to mobile radio active bug. If you use mobile data battery drain is quicker as compared to wifi. Click on those battery consuming services and check the time taken by mobile radio active
  10. return.of.octobot
    Chugz likes this.
  11. malidan
    Marshmallow May 17, 2015
    malidan , May 17, 2015 :
    Lol why would you post such stats as to mislead, when you have odviously tweaked the life out of the Os and your running nowhere near stock? IE " kernal tweaker has been allowed".:rolleyes:
    There are miracle OS's out there any swap on the same version will be in the -1 / +1 range
    Chugz likes this.
  12. return.of.octobot
    Jelly Bean May 17, 2015
    return.of.octobot , May 17, 2015 :
    Idk how misleading it is, many of us tweak our kernels to achieve better performance. I for one am a heavy kernel tweaker, and even with serious modifications I've never been able to achieve stats anywhere close to that. So, if the stock battery life is even half as good as what his screenshots indicate, it's still really really good.
    I'm about to find out for myself anyway.
    Utkarsh verma and Chugz like this.
  13. malidan
    Apparently not they released a 5.1.1 yesterday.
    https://www.androidfilehost.com/?w=files&flid=27352
    Bro its obviously awake then as many have previously stated goto privacy and turn off keep awake and wake device on all Google apps. If you rooted and have custom recovery, wipe cache and delvik and install another set of gapps:http://forum.xda-developers.com/slimroms/general/gapps-official-slim-gapps-trds-slimkat-t2792842
  14. return.of.octobot
    Utkarsh verma likes this.
  15. malidan
    Most likely running 1.2 and 1.7 on CPU, GPU down to 27 mhz etc.
    You know I just had the same thought, the ROM is downloading as we speak;)
    Chugz and return.of.octobot like this.
  16. malidan
    Lol thought I deleted that, I types it then saw your comment.
    return.of.octobot likes this.
  17. return.of.octobot
    Some screenies, this is baseline, only thing I've done is enable on-sceeen nav. Like I said, a lot of very unique stuff going on here.
    Back on my primary for now, but will definitely take some time to put Broken through it's paces later on.
    Utkarsh verma and malidan like this.
  18. malidan
    I have to wonder about this device sometimes. I take it from what your saying you get 4-5 hrs sot.
    I managed to get 5-6 from nocturnal with no other than good practice and I do play a juice sapping game on ave 45 min per day.
    #38
  19. return.of.octobot
    I actually average between 6-8, currently running Commotio but I've manage to hit that mark on several ROMs, always with AK tweaks, SetCPU, greenify, amplify, etc. etc. The usual tricks.
    #39
  20. aenews
    KitKat May 17, 2015
    aenews , May 17, 2015 :
    Do you at least have root? I'd say Greenify should be a great help even without root. With root and XPosed, it's even better. If you use Xposed, I'd recommend trying the Amplify module as it lets you control your wakelocks and how frequently they can activate.
    Also, even without root, you can adjust your performance settings as long as developer's options are turned on (Tap Build Number 5-10X under About Phone). You can try different governors and see if they improve battery life during active usage.
    #40
