3
Battery 94% - 5 Hrs left... ???
  1. malidan
    Marshmallow May 17, 2015
    malidan , May 17, 2015 :
    I just installed it. I see what you mean impressive boot animation, it stimulates the interest a little more.
    #41
  2. return.of.octobot
    Jelly Bean May 17, 2015
    return.of.octobot , May 17, 2015 :
    I just think it's pretty interesting, I noticed a lot of small, but cool things that I haven't seen elsewhere like the translucent keyboard, the power menu, stock V4A and overall I'm finding the settings elements and available tweaks to be pretty impressive.
    I think, from what I read it may come stock with AK as well. Don't quote me on that as I flashed the latest version with the synaptics drivers just to be on the safe side. Maybe you can confirm.
    #42
    malidan likes this.
  3. malidan
    Yep AK on splash screen but its not saying that in performance. I'm gonna swap it to primary and have a play tomorrow
    #43
    Utkarsh verma likes this.
  4. return.of.octobot
    Right on. If you've got the splash screen, it's probably a safe bet, but it should also be visible in settings -> about phone.
    I'm going to play with it further later on tonight, seems pretty promising though. Like I said, I'm a little bummed on the lack of CM theme engine, but it does have layers, which I understand more or less a non-CM themer, I'm just not familiar enough with it at this time to have a good grip on it's capabilities.
    We could be on to something here.
    #44
  5. return.of.octobot
    #45
    Utkarsh verma and DaxNagtegaal like this.
  6. sgpk348
    Cupcake May 17, 2015
    #46
  7. malidan
    Mine says something totally different
    #47
  8. malidan
    What do you want to know bud
    #48
  9. abhishekezio
    Gingerbread May 17, 2015
    abhishekezio , May 17, 2015 :
    Allow the kernel time to settle,use greenify and privacy guard to deny google play services. You won't see results instantly, but over a period of 10-15 days , you surely will. I'm on COS12 and my battery life increased remarkably over the past few days. I used to get 3-4 hrs SOT just after updating, but yesterday I got 6 hr 54 mins usage with 5% left which is pretty sufficient for me.
    #49
  10. malidan
    The ROM is impressive, and the ram idle is very low in comparison to all the ROMs I've used recently.
    The benchmark is low but the OS seem very fast and the browser loads faster than anything else I've used.
    More screenshots Screenshot_2015-05-17-09-59-45.png Screenshot_2015-05-17-09-59-05.png Screenshot_2015-05-17-09-59-56.png
    #50
  11. malidan
    #51
  12. BRADn7
    #52
  13. ThijsOne+1
    ThijsOne+1 , May 17, 2015 :
    Try tot install the CM12 nightlies, with the AK kernel installed. It works very well!!!
    #53
  14. DaxNagtegaal
    DaxNagtegaal , May 17, 2015 :
    Will flash soon
    #54
  15. djbenny1
    djbenny1 , May 17, 2015 :
    I gave it a quick try yesterday, the customisation is really brilliant, much like Venom ROMs on HTC.
    It does have a few bugs though at the minute.
    #55
    DaxNagtegaal likes this.
  16. DaxNagtegaal
    #56
  17. bmark240
    Ice Cream Sandwich May 17, 2015
    bmark240 , May 17, 2015 :
    What some people forget about cache is that in Lollipop, there is also an option in Settings->Storage->Scroll down until you see Cached Data->Press on the words Cached Data->it will popup if you want to clear cache it will keep lots of Gb of cache there. I dont think that TWRP can clear the cache as its no longer Dalvik Runtime but ART (android run time).Also just underneath this is Misc. Do the same & tick what you want to delete.
    #57
  18. djbenny1
    Can't remember them to be honest, on their Google+ community you can read about it in the device specific section.
    For me, the deal breakers were the hardware button lights won't go off unless you use a third party app and it just wasn't as slick as CM12.1.
    Ill definitely try it again when they fix the backlight thing though.
    #58
  19. return.of.octobot
    Basically the backlight on the hard buttons is pretty wonky and sometimes turns on after being disabled, but I managed to shut it down for good with the keyboard backlight app.
    #59
  20. Utkarsh verma
    Froyo May 17, 2015
    Utkarsh verma , May 17, 2015 :
    The thing is i installed broken as multirom, and was enjoying it , but then i found miui rom so wanted that to flash too as multirom(like i do generally) every thing went great in miui all thing were good untill i rebooted back to brokenos and guess what everything broke like its name sytem has crashed all apps were crashing etcetcetc even the system apps as well , i dont know what went bad coz in multirom no rom is linked to each (as far as i know) but that mi shit really broke my brokenos. Now will have to install it again (hopefully will be doing it tonight) then i will be able to tell u about twikings i had done before. (coz i dont rem. Every thing i twiked)...
    #60
