Battery and Heating issue
  1. Dry_High_raj_kundu_
    Cupcake Sep 2, 2017
    Dry_High_raj_kundu_ , Sep 2, 2017 :
    After the oxygen os 4.1.7 update my Op3 battery doesn't even last for 3hours....I have to keep on charging my phone... Actually the battery performance was good when it was on marshmallow 6.0
    This is very disappointing one plus.!!!
  2. vgupta1192
    Gingerbread Sep 2, 2017
    vgupta1192 , Sep 2, 2017 :
    battery issue exist in android devices after kitkat..
    so nothing major done by oneplus
    blame google for spoiling android
  3. mindhead1
    Donut Sep 2, 2017
  4. frankkn85
    Eclair Sep 2, 2017
    frankkn85 , Sep 2, 2017 :
    try clearing cache files by entering recovery mode had read in community and it kind of improved my battery life I was having same issue..bit better now
  5. G_shoo_kah_chon_miGi
    Donut Sep 2, 2017
    G_shoo_kah_chon_miGi , Sep 2, 2017 :
    try clear cache, if the problem still persist, you may need to consider factory reset your device, my OP3T running 4.1.7, battery is perfect..
  6. VaibhavBhargava
    Lollipop Sep 2, 2017
    VaibhavBhargava , Sep 2, 2017 :
    In KitKat there was the camera daemon issue (which used to eat up all battery unless the phone was restarted)
  7. vgupta1192
    but that was not as bad as all the other issues introduced by android latest iterations
  8. VaibhavBhargava
    Lollipop was fine (Moto g 1st gen)
  9. vgupta1192
    had it has kitkat then it would have been more than fine.
  10. VaibhavBhargava
    it came with 4.3 then 4.4.2, then i switched to its beta program for lollipop
