4
Battery backup became too poor after 2nd update.How to fix that?
  1. Alen Marian Donut Jun 13, 2018
    Alen Marian, Jun 13, 2018 :
    How to Fix battery drain problem for op6? Issue started in first update and after 2nd update it became increased.How to fix this?
  2. G_Joseph_Daviez_XROE Honeycomb Jun 13, 2018
  3. NovinDavis KitKat Jun 13, 2018
  4. kannanprithiviraj Cupcake Jun 13, 2018
  5. Prcko Jelly Bean Jun 13, 2018
  6. kannanprithiviraj Cupcake Jun 13, 2018
  7. T1528699093773 Cupcake Jun 13, 2018
  8. F_Lalit_Kashyap_MuDD Eclair Jun 13, 2018
  9. Prcko Jelly Bean Jun 13, 2018
    Prcko, Jun 13, 2018 :
    next time use search function. you don't need to wait for answer
  10. gunu@123 Donut Jun 13, 2018
  11. Terryruiz Ice Cream Sandwich Jun 13, 2018
  12. ksjha70 Cupcake Jun 13, 2018
    ksjha70, Jun 13, 2018 :
    i purchase OnePlus 6 through Amazon 2 day back.battery draining fast . should I return it?
  13. T1528699093773 Cupcake Jun 13, 2018
    T1528699093773, Jun 13, 2018 :
    @ksjha70 try to update using Canada VPN and check your battery backup after update many optimization have been done in the update it may fix ur problem if not then think of other solution
  14. ksjha70 Cupcake Jun 13, 2018
  15. T1528699093773 Cupcake Jun 13, 2018
  16. Natarajan_rahul Cupcake Jun 13, 2018
  17. B1527690292138 Cupcake Jun 13, 2018
  18. ksjha70 Cupcake Jun 13, 2018
  19. ksjha70 Cupcake Jun 13, 2018
  20. G_Joseph_Daviez_XROE Honeycomb Jun 13, 2018
    Terryruiz likes this.
