battery backup down from 26hrs to 17 hrs after updating 4.0.3 in normal use
  1. cool.ashish.v
    Eclair Feb 14, 2017
    cool.ashish.v , Feb 14, 2017 :
    battery backup down from 26hrs to 17 hrs after updating 4.0.3 in normal use, I wipe cashe ,should I reset . but if I neet to reset every time after update than it is the problem.
  2. Master_TC
    KitKat Feb 14, 2017
    Master_TC , Feb 14, 2017 :
    I would wait for some days and look what drains your battery.
    Perhabs it´s only a issue for some days...o_O
    airiartev likes this.
  3. cool.ashish.v
    Eclair Feb 14, 2017
  4. Bartnl
    Lollipop Feb 14, 2017
    Bartnl , Feb 14, 2017 :
    After an update or cache wipe your phone needs to work harder to fill the cache again a d to settle down. This is costing extra power.
    Just use it for some days and you will see the battery life will increase.
  5. Ultra.Numan
    Honeycomb Feb 14, 2017
    Ultra.Numan , Feb 14, 2017 :
    Usually takes a couple of charging cycles to come back up.
    Saying that I don't understand why it happens, would love to know the answer to that not the what to do?
  6. F_Imtiaz_Fahad_Badhan_vm
    Froyo Mar 6, 2017
  7. Dunnow
    The Lab - OnePlus 6 Reviewer Mar 6, 2017
    Dunnow , Mar 6, 2017 :
    Theres no such thing as batter backup. You cannot backup battery.
